Massive battery life drop after installing Oreo
  1. d'andrea Cupcake Jan 3, 2018
    d'andrea, Jan 3, 2018 :
    After my post of two days ago, I report another massive battery life drop! Today it is the worst charge duration ever! 16 hours with 100% charge and 5 hours left with 32% charge, due to the Google Play Services app, with normal use of the device.
    The phone is very hot too.
    Please do something!
  2. CosmoKramer70 Ice Cream Sandwich Jan 3, 2018
    CosmoKramer70, Jan 3, 2018 :
    go and wipe the cache, to find out how to do it search and you'll find the solution. this sort of issues has been posted multiple time, search is your friend.
    Hydra Bob likes this.
  3. gREENNNNN Eclair Jan 5, 2018
    gREENNNNN, Jan 5, 2018 :
    same problem here. Wiping cache doesnt work at all with this issue so STOP recommending it.
  4. wileyc Jelly Bean Jan 5, 2018
    wileyc, Jan 5, 2018 :
    Go to settings>battery. What is sucking the power? Also - if you have just installed give it a few days to settle down. Most battery problems are related to apps used and usage patterns. Few are genuinely caused by a new OS release. Oh and wipe the system cache in recovery mode. I do this after each release install.
