4
Math Puzzle - Are you smarter than a Singaporean 6th grader?
  1. bounpong
    Cupcake Apr 22, 2015
    bounpong , Apr 22, 2015 :
    Take the rope out and measure. So easy!
    #41
    jma9454 likes this.
  2. rtomb
    Honeycomb Apr 22, 2015
  3. Adam8g
    Adam8g , Apr 22, 2015 :
    YES
    If you flatten the cylinder - you get a rectangle...4 cm by 12 cm
    There are four 3 4 5 right triangles.
    the sum of the hypothenuses (is that right??) is 20 cm
    #43
  4. Adam8g
    #44
    Ceasedd and Reus like this.
  5. Ces
    Gingerbread Apr 22, 2015
    #45
  6. Adam8g
    #46
    Ceasedd and Tobikage like this.
  7. hamzwe55
    Gingerbread Apr 23, 2015
    hamzwe55 , Apr 23, 2015 :
    That's what I said. So where's my fame?
    #47
  8. Reus
    Jelly Bean Apr 23, 2015
    #48
  9. Tobikage
    General Support Expert Award 2021 Apr 23, 2015
    Tobikage , Apr 23, 2015 :
    It's been delayed...just a bit...expect it in a week or two..
    #49
    meatandy, Ceasedd and hamzwe55 like this.
  10. iDelirious
    iDelirious , Apr 23, 2015 :
    There's one issue I see here though, what you labelled 4cm is the diameter, the question states that the circumference is 4cm. Circumference =/= diameter, so either 20 is incorrect or the question is phrased incorrectly.
    Edit: Took a closer look at the question, I see where I went wrong. 20 is the correct answer.
    #50
  11. hamzwe55
    Just like the release of CM12
    #51
    Tobikage likes this.
  12. mydroid
    KitKat Apr 23, 2015
    mydroid , Apr 23, 2015 :
    The answer is simple that's why we hire them Singaporeans to do all the smart work while we chill in Bahamas....
    #52
  13. Curt0176
    Ice Cream Sandwich Apr 23, 2015
    #53
  14. ifrahim07
    #54
  15. MattB16
    #55
  16. StinkySocky
    StinkySocky , Apr 23, 2015 :
    You guys realize 16 will only get you around the rod four times, but it won't get you across, right?
    #56
  17. lostLambda
    Lollipop Apr 23, 2015
  18. JeanLeFleurantin
    Donut Apr 23, 2015
    #58
  19. Dr. Indest
    Dr. Indest , Apr 23, 2015 :
    That wasn't very nice. I can ask you a question I am sure you will get wrong, yet are you a "retard"?
    People have different strengths and weaknesses. Kindness makes the world go round.
    Also, looking up an equation on Google does not make you smart. Being able to calculate that will get you no where in life unless you are an engineer.
    #59
    EpicSwirly likes this.
  20. EpicSwirly
    EpicSwirly , Apr 23, 2015 :
    lmao i just jokes you da best
    #60
    Dr. Indest likes this.
