McLaren 7t pro different model numbers
  1. Ali18
    Donut Jan 12, 2020
    Ali18 , Jan 12, 2020 :
    I'm interested in getting the unlocked version of the McLaren 7t pro. I'm seeing two model numbers 1910 and 1913. what's the difference between the two? I'm in the US but need the dual SIM version.
    Currently with T-Mobile, will these international models get 5G?
  2. 5urv1v0r
    Donut Jan 12, 2020
  3. pauljbutcher
    Eclair Jan 12, 2020
    pauljbutcher , Jan 12, 2020 :
    The only McLaren to support 5G is the 1925.
    You may be able to get dual SIM support with the 1925 after carrier unlock as the hardware is built into the phone but will require a dual SIM tray and for you to write a second IMEI to the phone after a carrier unlock and root.
    I have owned a 1913 and it works fine in the US as well.
  4. Ali18
    Donut Jan 14, 2020
  5. Ali18
    Donut Jan 16, 2020
    Ali18 , Jan 16, 2020 :
    Just got the 7T McLaren 1913. Great phone, that 90hz display is amazing
  6. ronnyhawks
    Ice Cream Sandwich Jan 20, 2020
    ronnyhawks , via OnePlus 7T Pro McLaren Edition , Jan 20, 2020 :
    no need for the "writing a 2nd sim" BS. it just uses the same IMEI from SIM 1. both work perfectly fine [e]1f44c[/e][e]1f44d[/e]
  7. pauljbutcher
    Eclair Jan 20, 2020
    pauljbutcher , Jan 20, 2020 :
    Wouldn't that prevent having two active SIM cards at the same time? At least on the same carrier I believe that would be the case. Maybe not if say one SIM was on T-Mobile and the other on AT&T.
  8. Ali18
    Donut Jan 20, 2020
  9. pauljbutcher
    Eclair Jan 20, 2020
    The 1913 came from the factory with two IMEI numbers. However, the 1925 does not.
