Media Volume Increases when disconnecting bluetooth headphones
  1. funkyant13
    Froyo Dec 16, 2019
    funkyant13 , Dec 16, 2019 :
    Hi all
    There is an issue when disconnecting bluetooth headphones. After disconnecting headphones the media volume goes to maximum.
    For example the media volume can be set to silent, connect headphones volume is fine, disconnect the headphones and the media volume is now maximum.
    I have tried with Blueooth absolute volume both on and off and I get the same result both times. Anyone know how to fix this?
    Testing on a OP7T running stock Oxygen OS 10.0.6HD65BA
    Have tested with 2 sets of bluetooth headphones from different manufacturers same result.
  2. HeeroML
    Gingerbread Dec 16, 2019
  3. funkyant13
    Froyo Dec 16, 2019
    Did you play anyrhing through the speaker?
    Just tested it again - It doesnt seem to be affected if you just connect and disconnect a headset however playing music on spotify or youtube and after disconnecting it goes to maximum.
  4. HeeroML
    HeeroML , via OnePlus 7T , Dec 16, 2019 :
    will try later, but I did play music afterwards
