Media volume issue. via OnePlus 7T
  1. asimpleim
    Donut Sep 28, 2021
    asimpleim , via OnePlus 7T , Sep 28, 2021 :
    Media volume is extremely low while on video or audio call. This issue I was facing few months before also it was got resolved after factory reset. But I cannot keep resetting my device. Kindly help if anyone has crack this issue.
  2. mjrtoo
    Eclair Sep 28, 2021
    mjrtoo , via OnePlus 7T , Sep 28, 2021 :
    I'd be curious if when you raise the volume it shows that you're in a phone call and the audio is coming out the earpiece instead of the speaker. I've been running into this issue recently myself.
    G_Luuk_MHVG and eliyahusa like this.
  3. eliyahusa
    Cupcake Sep 29, 2021
    eliyahusa , Sep 29, 2021 :
    I have the same issue. Don't no how to fix it
  4. mjrtoo
    Eclair Sep 29, 2021
    mjrtoo , via OnePlus 7T , Sep 29, 2021 :
    I tried this and so far it seems to be working, as it says in the procedure you will lose all your current Bluetooth parings and stored wifi login data. In my case I also lost my mobile APN data but this is a special case, I'm using a non standard provider.
  5. Drasm19
    Ice Cream Sandwich Sep 29, 2021
    Drasm19 , Sep 29, 2021 :
    Thanks!
  6. eliyahusa
    Cupcake Sep 30, 2021
    eliyahusa , Sep 30, 2021 :
    I tried this and it help for couple hours.
    Still need to fix this issue.
  7. mjrtoo
    Eclair Oct 1, 2021
    mjrtoo , via OnePlus 7T , Oct 1, 2021 :
    Strangely, mine is still working.
  8. D1548785929994 , via OnePlus 8 T-Mobile , Oct 18, 2021 :
    Facing Same Issue Any Solution For This
  9. mjrtoo
    Eclair Oct 18, 2021
  10. #10
