5
Media volume very low when connected to Bluetooth device
  1. omar10wahab
    Cupcake Mar 20, 2019
    omar10wahab , Mar 20, 2019 :
    Have the same problem where my car has a bluetooth receiver where i max the volume output and it works fine. Usually its always whatever the max volume i can output but if i connect my wireless headphones, its having issues now determining what is the actual max volume for the device. I can confirm that forgetting the device does fix the issue but this issue pops up enough times that its not a good solution. The developer setting solution that was suggested above does not work for me. My theory is that, based on my understanding, oneplus/android now has a feature to remember volume settings per device and because of this function it messes with the actual settings per device. My volume slider always seems to be set at max but i only set my car bluetooth to max. I set my wireless headphones to somewhere in the middle but when i connect the volume slider is set at max. So now its thinking my max is now somewhere in the middle. I can confirm it does still decrease volume every level but in smaller increments then if the max volume was the correct level. I'm not sure but if theres a way to clear this settings outside of forgetting the device or even disabling the feature that would probably be the solution. I think this is the issue but i could be wrong
    rickyone likes this.
  2. rickyone
    Cupcake Jun 12, 2019
    rickyone , Jun 12, 2019 :
    Thank you Fernando!
    That worked for me.
    In addition to what you did, after disconnecting the wired headphones and reconnecting my Samsung Buds, I just had to try adjusting the volume down and the voice suddenly got higher.
    Riccardo
  3. H1534226117485
    Cupcake Jun 15, 2019
    H1534226117485 , Jun 15, 2019 :
    Thanks it worked for me the low volume had anoyed me for a while now and decided now that i had time to search and figure it out.
    yka1988 likes this.
  4. P1564391588291
    Cupcake Jul 29, 2019
    P1564391588291 , Jul 29, 2019 :
    I'm having a similar issue that I get full sound when the sound bar is set to somewhere around low. When I try to increase or decrease it suddenly no sound at all and when sound bar set to somewhere near max it gives medium sound, it's so strange and happened out of nowhere. I have tried forgetting the device, clearing cache, resetting my phone, and developer mode solution and none of it worked so far.
  5. sgotthard
    Cupcake Oct 10, 2019
    sgotthard , Oct 10, 2019 :
    I have the same issue with my Sony 1000xm3 after about 6 months of working fine. Tried all of the above mentioned solutions to no avail. Can't confirm that it started with the new patch mentioned above but its likely.
    Hopefully this can be fixed by a quick patch, cause I haven't been able to find a manual fix.
  6. rakshithrajesh30
    Cupcake Jan 28, 2020
    rakshithrajesh30 , via OnePlus 6 , Jan 28, 2020 :
    works thanks for the advice.
  7. goutamar
    Cupcake Mar 11, 2020
    goutamar , via OnePlus 5 , Mar 11, 2020 :
    I also did the same thing now it's working fine Thanks
  8. VelPrabanidhi
    Cupcake Mar 18, 2020
    VelPrabanidhi , via OnePlus 7 Pro , Mar 18, 2020 :
    caotico
    I've tried this but to no avail. I'm using some Anbes headphones that worked great until about a month ago. Now full volume is just below normal listening, but they work fine from another source. I've tried forgetting and re-pairing. I've disabled and enabled absolute volume. No difference for me. It seemed like maybe there was an update that messed up my bluetooth volume. Combine that with no headhpone jack...not cool. I hope they fix this.
    edit: I'm on a 6T. Didn't realize this was a 5T thread.​
    I tried all of the above instructions. But I having same that problem.. I'm. Using. 7 pro and the. Bluetooth headset is. Sony. Wi c300.. Media volume very low when connected to Bluetooth device...
  9. MirceaForce
    Honeycomb Mar 28, 2020
    MirceaForce , Mar 28, 2020 :
    even on 7t pro is the same issue no fix here...oneplus should provide a fix for this ....
  10. deadsar17
    Cupcake May 6, 2020
    deadsar17 , May 6, 2020 :
    Kudos to you sir.
    This solved my problem too. I have OnePlus 5 unit and Razer Hammerhead True Wireless Earbuds but I've suddenly noticed a significant decrease on the Bluetooth volume even though it maxed.
    Thank you Fernando
  11. S1562221683203
    Cupcake Jul 18, 2020
  12. Lars Fi
    Cupcake Jul 29, 2020
    Lars Fi , Jul 29, 2020 :
    Same issue with my new bluetooth device ... it really sucks
    any other ideas?
  13. swatej_k
    Cupcake Jul 30, 2020
    swatej_k , via OnePlus 7T , Jul 30, 2020 :
    Connected Sony WH-1000XM3.. swipe up on the touch panel doesn't change the volume..
    Maxed out volume on the phone ... Volume is still low..
    This doesn't happen with Pixel 2, Nexus 6p, Mi A2..
    Current phone One Plus 7t
  14. SmartDust
    Cupcake Aug 2, 2020
    SmartDust , Aug 2, 2020 :
    Had this issue (probably after firmware update) connecting to my Fiio BTR3. Re-"pairing" solved the issue! Thanks
  15. Bendi5
    Cupcake Aug 27, 2020
    Bendi5 , Aug 27, 2020 :
    Had the same issue since August (probably after firmware update too). Re-pairing the device (removing + associating it again) solved my problem too. Many thanks! :)
  16. jkerkhoven
    Cupcake Nov 4, 2020
    jkerkhoven , Nov 4, 2020 :
    The same problem here: forgetting and reconnecting to my wf-1000mx3 did the job. Thanx!
  17. BetaBot
    Jelly Bean Nov 5, 2020
