9
[Mega Thread] All about Smart Lock / Face unlock
  1. MentalDraco KitKat Nov 17, 2017
    remedy likes this.
  2. G_vikas_hadavle_gjzb Cupcake Nov 17, 2017
  3. marcusskyfall Jelly Bean Nov 17, 2017
    marcusskyfall, Nov 17, 2017 :
    If seven of nine is involved then I'm in! :)
    lostLambda likes this.
  4. lostLambda KitKat Nov 17, 2017
    lostLambda, Nov 17, 2017 :
    Lol! I loved Voyager!
    marcusskyfall likes this.
  5. canucks4life Gingerbread Nov 17, 2017
    canucks4life, Nov 17, 2017 :
    I disagree if it is indeed software based in combination with front camera they should update OOS to allow Face unlock for OP5 devices as well.
    There is ongoing issues with Google smart lock services not working correctly as you can tell by top pin OP5 support page...pointing the finger @ Google plus a reboot workaround doesn't cut it.
  6. malidan Lollipop Nov 17, 2017
    malidan, Nov 17, 2017 :
    If they were using something like what Apple are using, the device would cost a lot more that's for sure.
    F_Terence_Quah_gSCv likes this.
  7. O1512394860362 Cupcake Dec 4, 2017
    O1512394860362, Dec 4, 2017 :
    when phone is locked it doesn't prompt for pin/pattern it unlocks directly when the unlock button is pressed
  8. Rizla Jelly Bean Dec 4, 2017
    Rizla, Dec 4, 2017 :
    I take it you have face unlock setup yes?
  9. O1512394860362 Cupcake Dec 4, 2017
  10. G_plusone KitKat Dec 4, 2017
  11. gauravnema Honeycomb Dec 4, 2017
    gauravnema, Dec 4, 2017 :
    Depending on what Smart locks you have active the Phone can stay unlock when:
    - It has not been rested flat on a table
    - It is at a trusted location
    - It is connected to a trusted device via Bluetooth
    It can also unlock when there is no security feature enabled.
    Please check your settings.
    If everything looks fine then you have perhaps created a deeper link with your phone. Deeper and more meaningful than any smartlock. (Jokes apart - Check your settings)
  12. B1513862437172 Cupcake Dec 21, 2017
  13. Jaswanth B2o Donut Dec 21, 2017
  14. nickhell Honeycomb Dec 21, 2017
  15. O1512394860362 Cupcake Dec 21, 2017
  16. Jatin_Haryani Cupcake Dec 21, 2017
    Jatin_Haryani, Dec 21, 2017 :
    I am unable to open smart lock window on my OP5T
    can anyone help me out??
    this is what appears on my screen [e]1f612[/e]
  17. dibon Donut Dec 21, 2017
    dibon, Dec 21, 2017 :
    I say what I was told here in forum and helped me after clearing cache did not helped me to see smart lock menu.
    Go to settings, trust agents, set off smart lock, restart the phone and switch on the smart lock back.
    In case clearing cache not helping you.
    Jatin_Haryani likes this.
  18. Mouhammad Alajooz Donut Dec 21, 2017
    Mouhammad Alajooz, Dec 21, 2017 :
    you have installed an application that changes the security options like outlook or IBM notes uninstall it and it will worj
    #38
  19. Jatin_Haryani Cupcake Dec 21, 2017
    nope i hadn't
    #39
  20. Jatin_Haryani Cupcake Dec 21, 2017
    thanx
    it worked[e]1f60a[/e]
    #40
    dibon likes this.
