838
[MEGA THREAD] Battery Calibration/Heating Tips: How To Improve Battery Life !!
What has been your first experience with the OnePlus 5 Screen-On Time?
  1. 3 Hours
    90 vote(s)
    5.3%
  2. 3.5 Hours
    73 vote(s)
    4.3%
  3. 4 Hours
    156 vote(s)
    9.2%
  4. 4.5 Hours
    183 vote(s)
    10.8%
  5. 5 Hours
    215 vote(s)
    12.7%
  6. 5.5 Hours
    183 vote(s)
    10.8%
  7. 6+ Hours
    793 vote(s)
    46.8%
  1. namono21 Eclair May 27, 2018
    namono21, May 27, 2018 :
    in the settings is for the apps cache, but you can also clean it from the recovery. chose whippe data and chache and then chose chache only, this way you will clean also phone system chache
    kaushaldevy likes this.
  2. ten_piseth Eclair May 27, 2018
    ten_piseth, May 27, 2018 :
    yeb seem strang after up date to 5.1.2 ,battery drain fast and i use Gcam and it heat up strangely.. never has that b4.
    namono21 likes this.
  3. namono21 Eclair May 27, 2018
    maybe you can fix it by cleaning the chache like everyone is saying.... apparently many have this problem and some others don't
    ten_piseth likes this.
  4. StanleyWs Eclair May 27, 2018
  5. G_Mr_.... Jelly Bean May 27, 2018
    G_Mr_...., May 27, 2018 :
    jeetendrachawda
    how to clear catches
    in setting​
    Hi here you go, I copied this from a previous thread saves time me writing it down all the time.
    Hope this helps.
  6. Shery4life Honeycomb May 28, 2018
    Shery4life, May 28, 2018 :
    I belive this might be some app misbehaving and I hope that's not the case with new update
  7. G_Harshith_nagaraj_vbNh Cupcake May 28, 2018
    G_Harshith_nagaraj_vbNh, May 28, 2018 :
    after the update to OS 5.1.1 , the phone is starting to discharge battery very quickly.. before the phone used to to last the whole day , but now i need to run for the charger every now and then.. plzz respond to this query as soon as possible..
  8. Shery4life Honeycomb May 28, 2018
  9. Shery4life Honeycomb May 28, 2018
  10. Shery4life Honeycomb May 28, 2018
  11. pablofg1978 Spanish POC Assistant Head Moderator May 28, 2018
  12. pablofg1978 Spanish POC Assistant Head Moderator May 28, 2018
    pablofg1978, May 28, 2018 :
    Merged
  13. BrainsCollector Honeycomb May 28, 2018
    BrainsCollector, May 28, 2018 :
    I have shit battery after 5.1.0 update (5.1.1 and now 5.1.2).
    I used to have 9H sot, now it's hard to reach 7h, mostly around 6. So 1/3 worse just because ... what ? Cleaning f cache once in a week after charging and it still gives shit.
  14. Shardul_deshpand Eclair May 28, 2018
    Shardul_deshpand, May 28, 2018 :
    Hey, have you perform factory data reset??
    pls reply asap so i get to know if it solves the problem
  15. C1514048526794 Froyo May 28, 2018
    C1514048526794, May 28, 2018 :
    After the recent update of OxygenOs the battery backup in my 5T has been considerably improved. It's been over a day and still i have 18% left and i have been using all third party apps that i have been using prior to this update. looking forward to Camera updates.
    Thank you OnePlus team
    never settle.
  16. Anmol Das Cupcake May 28, 2018
  17. MentalDraco Lollipop May 28, 2018
    manuel19 and izzykasha like this.
  18. izzykasha KitKat May 28, 2018
    izzykasha, May 28, 2018 :
    I do wonder what these users do and put on their phones lmao
    manuel19 and MentalDraco like this.
  19. MentalDraco Lollipop May 28, 2018
    MentalDraco, May 28, 2018 :
    Malware apps. That push adds and steal data.
  20. G_Steve_Turri_ibLE Donut May 28, 2018
