839
[MEGA THREAD] Battery Calibration/Heating Tips: How To Improve Battery Life !!
What has been your first experience with the OnePlus 5 Screen-On Time?
  1. 3 Hours
    90 vote(s)
    5.3%
  2. 3.5 Hours
    73 vote(s)
    4.3%
  3. 4 Hours
    157 vote(s)
    9.3%
  4. 4.5 Hours
    183 vote(s)
    10.8%
  5. 5 Hours
    215 vote(s)
    12.7%
  6. 5.5 Hours
    183 vote(s)
    10.8%
  7. 6+ Hours
    793 vote(s)
    46.8%
  1. Dunnow The Lab - OnePlus 6 Reviewer May 28, 2018
  2. pablofg1978 Spanish POC Assistant Head Moderator May 28, 2018
  3. Budruel Jelly Bean May 28, 2018
    Budruel, May 28, 2018 :
    And you feel the need to open a thread instead of using the existing one. Do not follow your instinct when you feel the need to commit suicide ...
  4. pablofg1978 Spanish POC Assistant Head Moderator May 28, 2018
    pablofg1978, May 28, 2018 :
    Thread merged
  5. kunalbapna Donut May 28, 2018
    kunalbapna, May 28, 2018 :
    Out of sudden the battery life has drastically reduced. Post full charge only 8hours of usage.
    Handset purchased this February.
  6. pablofg1978 Spanish POC Assistant Head Moderator May 28, 2018
    Thread merged
  7. J1513645375102 Cupcake May 28, 2018
  8. Antony Felix Donut May 28, 2018
  9. drumil17 Eclair May 28, 2018
  10. J1513645375102 Cupcake May 28, 2018
    J1513645375102, May 28, 2018 :
    I did, but no use..,
  11. drumil17 Eclair May 28, 2018
    drumil17, May 28, 2018 :
    Did you give it one more charging cycle? I would suggest you give it one more full cycle and see if it happens again or no? If it does report.. Normally any update on already present ROM can cause issues which can be solved by wiping cache.. So that's the solution as of now.. If not report it
  12. J1513645375102 Cupcake May 28, 2018
    ok...
  13. F_Chandan_Jha_piBj Donut May 28, 2018
  14. chaitanyabatra Donut May 28, 2018
  15. the_o2 Lollipop May 28, 2018
    the_o2, May 28, 2018 :
    Clear the cache partition from recovery mode as his problem solved
    your problem might also get solve..
  16. pablofg1978 Spanish POC Assistant Head Moderator May 28, 2018
    Thread merged
  17. ten_piseth Eclair May 28, 2018
    ten_piseth, May 28, 2018 :
    after clear cach and turn off location accuracy..bettery perfect, never last this long..
    let's test some more days.
    G_Mr_.... and namono21 like this.
  18. namono21 Eclair May 28, 2018
    namono21, May 28, 2018 :
    thank you guys for your efforts, hopefully this will help anyone who needs it....
    ten_piseth and G_Mr_.... like this.
  19. Morris.c Donut May 28, 2018
    Morris.c, May 28, 2018 :
    This is what I did:
    -Updating from 5.1.1 to 5.1.2
    -Hard reset to factory data
    -No social Apps installed (only Whatsapp and Telegram)
    -Weather App uninstalled
    -Gmail, Google Photos, Drive, Duo,YouTube ---> Disabled
    -Every Backup OFF
    -GPS/ bluetooth/NFC ---> OFF
    -GPS on Battery Saving mode
    -No Google Now/Assistant
    -No Google Location History
    -Google Chrome sync turned OFF (no account signed)
    -Good Signal, using 4G.
    Again, only using Mobile Data connection the Google Play Services are still on top of the battery usage. I'm almost sure it's an OS issue....
  20. Kytharsis Lollipop May 28, 2018
    Kytharsis, May 28, 2018 :
    Check your Google account syncing.
