774
[MEGA THREAD] Battery Calibration/Heating Tips: How To Improve Battery Life !!
What has been your first experience with the OnePlus 5 Screen-On Time?
  1. 3 Hours
    87 vote(s)
    5.3%
  2. 3.5 Hours
    70 vote(s)
    4.3%
  3. 4 Hours
    146 vote(s)
    9.0%
  4. 4.5 Hours
    169 vote(s)
    10.4%
  5. 5 Hours
    208 vote(s)
    12.8%
  6. 5.5 Hours
    174 vote(s)
    10.7%
  7. 6+ Hours
    774 vote(s)
    47.5%
  1. Icecreamypie Ice Cream Sandwich Dec 10, 2018
  2. arpit.taneja Cupcake Dec 10, 2018
    arpit.taneja, Dec 10, 2018 :
    hi,
    I have observed that my OP 5 battery is draining fast even the usage remains the same, life of battery is reduced by 4-5 hours.
    please let me know how can I resolve this issue
  3. mmansel Cupcake Dec 11, 2018
    mmansel, Dec 11, 2018 :
    my battery over the last few days have been crashing
    harder than a fat kid on a see-saw
  4. karanshar Donut Dec 11, 2018
  5. G1524903067311 Cupcake Dec 11, 2018
    G1524903067311, Dec 11, 2018 :
    Yes.. I also have the same problem.. GPS is consuming more power than the screen which is surprising.. Need solution to this problem.. Can anyone help me out out.. This is especially happening after 5.1.7 update..
  6. E1513163444138 Cupcake Dec 11, 2018
  7. R1544542218567 Cupcake Dec 11, 2018
    R1544542218567, Dec 11, 2018 :
    I have not updated yet due to the batt issue mentioned by a lot of users. Is the update necessary for the next update to be compatible?
  8. G1519005640596 Cupcake Dec 11, 2018
    G1519005640596, Dec 11, 2018 :
    hi one plus team could you work on battery drain issue one plus 5t update. before the update I used to get battery for 20- 23 hrs.
    Could someone provide a solution or release the new update for the fix. I have already optimise the battery. so no need to suggest optimisation.
  9. Waveform Modifier Lollipop Dec 11, 2018
    Waveform Modifier, Dec 11, 2018 :
    Please use search and visit the pinned battery thread for more information.
    TheBenjibenji likes this.
  10. Madnezz4Ever Honeycomb Dec 11, 2018
  11. Cervantes Lollipop Moderator Dec 11, 2018
    Cervantes, Dec 11, 2018 :
    Please, read the first and second post
    use the topic search instead of opening a new thread
    Thread merged
  12. G1519005640596 Cupcake Dec 12, 2018
    G1519005640596, Dec 12, 2018 :
    I had same app before the update and I had 24 hours backup. now it is reduced to 8 to 9 hrs. how will it happen all of sudden.
  13. HiroCBox Donut Dec 13, 2018
    HiroCBox, Dec 13, 2018 :
    wtf is 14% usage of Android OS? This problem is occurring since I updated to latest OS version. Before I update, I'm sure that there was about 65-70% battery left for same usage. I've tried most of solutions about battery problem like clearing cache, apps optimization, turning on app wifi multi broadcasting filter and so on. I read a lot of threads about solving battery drain but i can't fix this...
    What should I do now?
  14. Naee The Lab - OnePlus 5T Reviewer Dec 13, 2018
    Naee, Dec 13, 2018 :
    After 5.1.7 my screen-on time has gone down to two hours, and my battery life is really bad. Im not even getting halfway through the day. What should I do?
  15. G_Ganesh_Jadhav_lOwh Donut Dec 14, 2018
  16. TheBenjibenji Eclair Dec 15, 2018
    sachkharb likes this.
  17. aanishjangra Cupcake Dec 18, 2018
    aanishjangra, Dec 18, 2018 :
    Guys, My OnePlus 5 battery has started showing some anomalous behaviour recently. I'm having following issues:
    1. Full battery charging takes around 2:30 hours.
    2. Battery is draining too fast and is inconsistent. One cycle gets drained in 5-6 hours of SOT while the next in 2-3 hours (light usage, most of the times).
    3. The phone shows "low battery shutdown" at 20-35% level. While this was rare in beginning, it now happens most of the times. I don't remember seeing less than 20% level in some last days.
    4. Sometimes, the battery level gets stuck at a point and do not move for like 1 hour and so.
    I've tried following methods to resolve the issue:
    1. Thinking of this as a software problem, I downgraded from 5.1.7 to 5.1.4 and then to 5.1.3. Being on 5.1.3 seems to solve slow charging problem but looks like "fast charging" has come with equally "fast discharging".
    2. Wiped cache in recovery (obviously!!!).
    3. Battery calibration method as directed in first post.
    Any other suggestions are welcomed.
    Also, I'm confused about the method in first post. Are we supposed to perform step 1 and 2 for 2-3 times or is it that one set of step 1-2 in three months or so?? Some doubt clearance is required.
    Thanks in advance.
  18. AbyssD Cupcake Dec 28, 2018
    AbyssD, Dec 28, 2018 :
    This guide is very dangerous there is a lot of cases where some phones when turning off from zero battery they wont turn on again, or the battery gets damaged! This thread is made from technician or just a member?
    omarmawal likes this.
  19. O1518020026752 Cupcake Jan 2, 2019
    O1518020026752, Jan 2, 2019 :
    yesterday update has drained battery and display settings have gone worse dim light where I can't increase light. reading fonts can't be seen or changed. update sucks..
  20. Hj2396 Cupcake Jan 6, 2019
