840
[MEGA THREAD] Battery Calibration/Heating Tips: How To Improve Battery Life !!
What has been your first experience with the OnePlus 5 Screen-On Time?
  1. 3 Hours
    90 vote(s)
    5.3%
  2. 3.5 Hours
    74 vote(s)
    4.4%
  3. 4 Hours
    158 vote(s)
    9.3%
  4. 4.5 Hours
    183 vote(s)
    10.8%
  5. 5 Hours
    216 vote(s)
    12.7%
  6. 5.5 Hours
    184 vote(s)
    10.8%
  7. 6+ Hours
    792 vote(s)
    46.7%
  1. sharmakartik93 Eclair Jan 21, 2019
    sharmakartik93, Jan 21, 2019 :
    Under Developer Options Enable App WLAN Multi/Broadcastting Filter. What does it do? Any negative effects of it? + Are these methods applicable on pie?
  2. 7598 Froyo Jan 22, 2019
    7598, Jan 22, 2019 :
    please guys the battery performance has been terrible after the pie update!! I'll attach the screenshot of the battery stats
    It's really shocking to see such a terrible performance !! I had very good infact excellent battery life before the update I'm in oxygen os 9.0.0 Android pie!!
  3. IWantSunshine Froyo Jan 25, 2019
    IWantSunshine, Jan 25, 2019 :
    It seems with Android Pie the battery last somewhat longer, which is good news.
    Also, I don't charge it to 100% all the time and definitely don't drain it to 0%. Usually I charge it to 80% and put it on charger around 30%. I have charger at home, at the office, portable charger in my backpack, there is always a charger around, so no reason why I should do 100% to 0% cycles. 80% to 30% cycles are much better, according to AccuBattery my OnePlus 5's battery lost only 1% capacity in 17 months!
  4. P1531478043075 Cupcake Jan 27, 2019
  5. ModLife Ice Cream Sandwich Jan 27, 2019
  6. F_Shiva_Prasad_zIGe Cupcake Jan 27, 2019
  7. Tcat007 Ice Cream Sandwich Jan 27, 2019
    Tcat007, Jan 27, 2019 :
    Did you wipe cache in recovery? You must have some app syncing or running in background. 9.0.0 isn't much different than earlier pie or Oreo. Check battery stats and what's running in background. Restrict some of those.
    F_Shiva_Prasad_zIGe likes this.
  8. F_Shiva_Prasad_zIGe Cupcake Jan 27, 2019
    F_Shiva_Prasad_zIGe, Jan 27, 2019 :
    k I'll check it
  9. valuable Froyo Jan 29, 2019
    valuable, Jan 29, 2019 :
    Hello friends,
    I have been using my OP5 device for 15 months and I think there might be an issue with charging/discharging skills.
    If I charge my device 100% while it is off, it discharges as expected (Got Like 1 hr SOT until it reaches from 100% to 90%).
    But if I again charge it fully while it is operating, although I give it some time after it reaches to 100% for battery calibration and refinement, I can get only 15 mins SOT until %90 percent.
    My behavior is same, city power is same and there is no consumption detail under battery section. Like 6-7% of battery has been vaporized if I charge it while it is on.
    I just wanna ask did you realize this behavior and what is the reason behind if you investigated it.
    PS:
    1. No consumption log under battery section.
    2. Every charging component is original. Not only me, after talking to my friend he said that his device acts similarly.
    3. Please do not show me the battery tips post, I am initiating this post to share and learn the reason behind it and overcome if possible.
    Regards.
  10. Abdullahkhambhat Cupcake Jan 30, 2019
  11. Aziz_Amin_Oneplus Jelly Bean Jan 30, 2019
    Aziz_Amin_Oneplus, Jan 30, 2019 :
    Guys my 5t charger is giving some strange charging, one time when I charge from 5% to 95% it finishes in 1 hour and 20 minutes and gives a good battery backup and then another time I charge it from 5% to 95% it finishes the charging in only 1 hour and gives a little worst battery backup, what's happening something is wrong, I charge my mobile after every 2 days of discharge? thanks.
  12. Laamapalmu Jelly Bean Feb 2, 2019
    Laamapalmu, Feb 2, 2019 :
    Can't say because I only get 3-4 hour SOT, thanks to Snapchat.
  13. X1520201608571 Donut Feb 2, 2019
  14. X1520201608571 Donut Feb 2, 2019
    X1520201608571, Feb 2, 2019 :
    thx for bullshit, do your job well, and in my next choice, iwill assess this nonsense (battery life)
  15. vinay 5t Honeycomb Feb 3, 2019
    vinay 5t, Feb 3, 2019 :
    did any one changed 5T battery out of warranty in india and how is your experienced and where
  16. Vijju143 Cupcake Feb 5, 2019
    Vijju143, Feb 5, 2019 :
    Hi team mine battery also draining rapidly in 2 hours
    100 to 3% is there any update to fix that
  17. miklin Cupcake Feb 5, 2019
    miklin, Feb 5, 2019 :
    The same problem after update. Battery going down. Not during 2 hours to 3%, but during a day to 30 - 40% (60 - 70% before upgrade :-(
  18. Vijju143 Cupcake Feb 5, 2019
  19. Vijju143 Cupcake Feb 5, 2019
  20. Tcat007 Ice Cream Sandwich Feb 5, 2019
