838
[MEGA THREAD] Battery Calibration/Heating Tips: How To Improve Battery Life !!
What has been your first experience with the OnePlus 5 Screen-On Time?
  1. 3 Hours
    90 vote(s)
    5.3%
  2. 3.5 Hours
    73 vote(s)
    4.3%
  3. 4 Hours
    156 vote(s)
    9.2%
  4. 4.5 Hours
    183 vote(s)
    10.8%
  5. 5 Hours
    215 vote(s)
    12.7%
  6. 5.5 Hours
    183 vote(s)
    10.8%
  7. 6+ Hours
    793 vote(s)
    46.8%
  1. Pahalj Cupcake Mar 29, 2019
    Pahalj, Mar 29, 2019 :
    This screenshot was taken when kept the phone on charging mode....
    And on carrying out *#808#'s process
    this message was showing
    charging status: charging
    but as u can see on top... their were no indication of flash charge or even normal charge
    Someone please help me out with this
    Thanks
  2. MarkyPancake Honeycomb Apr 2, 2019
    MarkyPancake, Apr 2, 2019 :
    Took my OP5 off charge when full around midnight and it's been left unused with the screen locked since and in nearly 17 hours of doing nothing, the battery has drained by 13%. Not liking 9.0.4.
    Edit: Just realised my 3T has been off charge for over 10 hours and I've used it several times with mobile data while at work and the battery has only drained by 8% compared to my 5 doing nothing.
  3. Rocky_Shaikh Gingerbread Apr 3, 2019
    Rocky_Shaikh, Apr 3, 2019 :
    I am facing the same problem. Dash charging has noticeably slowed down from 70% to 100%. I tried various troubleshooting methods like battery calibration, cache clearing, changing power supply, changing cable and power brick and cleaning ports. It takes like 2 hour to charge from 70 to 100. I checked in through ampere app to get the readings, to my surprise it is charging just at paltry 100 mah rate after 70%.
    V1557500340333 likes this.
  4. C1516550706033 Cupcake Apr 14, 2019
  5. Vijju143 Cupcake Apr 15, 2019
    Vijju143, Apr 15, 2019 :
    what kind of thread to my battery
    I was used only 2 hours only it was showing u r used more than usual . I was kept a charging to my phone it was not working this is 3rd time happen to my mobile
    is there any solution..... plz tell me
  6. B1555328468576 Cupcake Apr 15, 2019
  7. I1553919918731 Cupcake Apr 16, 2019
    I1553919918731, Apr 16, 2019 :
    Hello everyone. I don't know about my phone now because when i started to use it for YouTube, game (just one time ML) and turn brightness over 50%, my phone going to be warm especially on camera area. The heat is more than my friend phone. So is that any ways to prevent it?
  8. Waveform Modifier Lollipop Apr 16, 2019
    Waveform Modifier, Apr 16, 2019 :
    Maybe you should get some diagnostic tools on the Play store and find out what is heating up first. The community will not do diagnostics for you.
  9. SoniaB Nougat Senior Moderator Apr 16, 2019
    SoniaB, Apr 16, 2019 :
    Thread merged
    Please seek assistance here and post your CPU temp stats
  10. Fursan Afzal Ice Cream Sandwich Apr 16, 2019
    Fursan Afzal, Apr 16, 2019 :
    This thread really turned it to be a Mega, surprising how common battery problems are in OOS.
  11. vinz_uk80 Gingerbread Apr 17, 2019
    vinz_uk80, Apr 17, 2019 :
    No issue at all with my OP5 under OB29, and battery life is GREAT.
    3 days on a charge, 6h of SOT and still 30% left. Love it.
  12. anupritaisno1 KitKat Apr 17, 2019
    anupritaisno1, Apr 17, 2019 :
    Charge your phone overnight and make sure it's turned on
    Dash charging cannot be used after 70%. Seriously. Anyone who thinks constant current charging after 70% is a good idea should prepare for an explosion. Your phone switches to constant voltage charging after 70%
    Uninstall pubg. Problem solved
    It is more like users do not know how to use their devices
    Is leaving your device on a charger at night that hard? Guess not. It improves battery but hardly anyone does it
  13. anupritaisno1 KitKat Apr 17, 2019
    Do note that many of the methods listed in this thread are pure myths and following them will only harm your device
    Battery calibration is a myth that actually harms your battery
    Wiping caches destroys everything your runtime ever created. It takes weeks for your system to recreate it and you'll face terrible lag and battery drain as it is recreating
  14. Rocky_Shaikh Gingerbread Apr 17, 2019
    Rocky_Shaikh, Apr 17, 2019 :
    i guess you have half baked knowledge about charging tech. It dash charges till 100, just the intensity of rate of charge decreases, if it doesn't dash charge then it shows red led Instead of blue led which confirms dash charge. I have used OnePlus 3, 3T, 5, and 5T, it never takes 3 hours to charge from 70 to 100.
  15. Rocky_Shaikh Gingerbread Apr 17, 2019
    i am very much familiar with it. Thank you anyways.
  16. anupritaisno1 KitKat Apr 17, 2019
    Maybe this is because you use the device way too much from that 70-100%? No phone will ever fast charge beyond 80% as that is unsafe
    If you were to force dash charge to 100% older batteries will definitely explode
  17. Rocky_Shaikh Gingerbread Apr 17, 2019
    I had reinstall the update and things are back on track.
  18. Rocky_Shaikh Gingerbread Apr 17, 2019
    I never use my phone during charging and It's common for batteries to charge slowly as it approaches 100 to preserve battery health.
  19. akshay_rk619 Cupcake Apr 19, 2019
    akshay_rk619, Apr 19, 2019 :
    I am gettin around 6hours of on screen time on full charge ...is fine ?? because I used to get around 7 hrs before..it it's a problem shod I check my phone battery ?? please do reply
  20. akshay_rk619 Cupcake Apr 20, 2019
    akshay_rk619, Apr 20, 2019 :
    what is SOT?
