56
Sound [MEGA THREAD] No ring on "ring mode" also.
Problem with sound notification
  1. How to fix the issue
    39 vote(s)
    97.5%
  2. any third party app?
    2 vote(s)
    5.0%
Multiple votes are allowed.
  1. Manas_Mishra_1989
    Ice Cream Sandwich Mar 1, 2018
    Ravi BINAVAT likes this.
  2. E1519923654642
    Cupcake Mar 1, 2018
    E1519923654642 , Mar 1, 2018 :
    how to download 5.0.4
  3. Manas_Mishra_1989
    Manas_Mishra_1989 , Mar 1, 2018 :
    The same way you did 5.0.3
    It is an OTA so it might take time to reach your country else you can download opera free VPN then change location to Canada in app then search System Updates in settings.
  4. crisp77
    Cupcake Mar 1, 2018
    crisp77 , Mar 1, 2018 :
    When will the other countries get the update? Hearing in coming calls is kinda fundamental part of a mobile phone!
    Ravi BINAVAT and Y1510639391080 like this.
  5. Manas_Mishra_1989
    There is no date on deliveries. Usually an update reaches round the globe in about 7-10 days. Else simply follow the VPN route and you can jump the line that way.
    For temporary fix you can first reboot device in recovery and wipe cache and then change the ringtone to any tone that comes pre installed.
    Ravi BINAVAT and crisp77 like this.
  6. vinodkp006
    Cupcake Mar 1, 2018
    vinodkp006 , Mar 1, 2018 :
    I am also facing the same after updating to 5.0.2.
    hoping one plus will solve the issue with upcoming update.if any other having any suggestions please post
    Ravi BINAVAT and Q1519916773610 like this.
  7. E1517902559205
    Donut Mar 1, 2018
    E1517902559205 , Mar 1, 2018 :
    hi guys
    I am facing some problem when incoming calls come the ringtone sound will not able to hear and notification sounds also after switch off the mobile phone will be normal. I am facing this problem today 3times ..can you help me
  8. CaptRosh
    Froyo Mar 1, 2018
  9. Mahmoud Mahafdah
    Gingerbread Mar 1, 2018
  10. E1517902559205
    Donut Mar 1, 2018
    tq bro
    Mahmoud Mahafdah likes this.
  11. Waveform Modifier
    Marshmallow Mar 1, 2018
  12. MrHari_theCarguy
    Jelly Bean Mar 1, 2018
  13. Nick 59
    Its.Leandroo likes this.
  14. NerdicEclipse
    Honeycomb Mar 1, 2018
  15. Lancelot_69
    Lollipop Mar 1, 2018
  16. F_Kishore_Budarapu_Padma
    Donut Mar 1, 2018
    F_Kishore_Budarapu_Padma , Mar 1, 2018 :
    I just noticed that after the phone has been paired to any other device using bluetooth, when the bluetooth is disconnected, the phone simply stops ringing. And no, it is not only on vibration, I made sure the volume was up. Received calls, no ringing, just vibration. Rebooted the phone, and ringing was back. Then, when I was about to sleep, paired my phone to a stereo in my room so that I could fall asleep while listening to music. Eventually, I fell asleep, the playlist ended, and the stereo turned off by itself. When I woke up this morning, I found out I had 4 missed calls, which was odd. I called to myself from my home's phone, and same thing: phone was vibrating, but not sounding, and yes, I made sure volume was up. Rebooted the phone, and again, problem was solved. And when I drove to work after that, connected the phone to the car (having the same issue as before, only being able to pair the multimedia part, but not the calling part), entered t
    he office, called to my phone from the office, and AGAIN, phone was vibrating, but not ringing. Rebooted the phone, and ringing was back.
  17. F_Kishore_Budarapu_Padma
    Donut Mar 1, 2018
    alok35935 and Ravi BINAVAT like this.
  18. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Mar 1, 2018
    NeVeR_SeTTLe , Mar 1, 2018 :
    Really? It's the worst device? Why?
  19. F_Kishore_Budarapu_Padma
    Donut Mar 1, 2018
    I just noticed that after the phone has been paired to any other device using bluetooth, when the bluetooth is disconnected, the phone simply stops ringing. And no, it is not only on vibration, I made sure the volume was up. Received calls, no ringing, just vibration. Rebooted the phone, and ringing was back. Then, when I was about to sleep, paired my phone to a stereo in my room so that I could fall asleep while listening to music. Eventually, I fell asleep, the playlist ended, and the stereo turned off by itself. When I woke up this morning, I found out I had 4 missed calls, which was odd. I called to myself from my home's phone, and same thing: phone was vibrating, but not sounding, and yes, I made sure volume was up. Rebooted the phone, and again, problem was solved. And when I drove to work after that, connected the phone to the car (having the same issue as before, only being able to pair the multimedia part, but not the calling part), entered the office, called to my phone from the office, and AGAIN, phone was vibrating, but not ringing. Rebooted the phone, and ringing was back.
    Serban Stelica and Ravi BINAVAT like this.
  20. NeVeR_SeTTLe
    When did this issue start happening?
