63
Sound [MEGA THREAD] No ring on "ring mode" also.
Problem with sound notification
  1. How to fix the issue
    43 vote(s)
    97.7%
  2. any third party app?
    2 vote(s)
    4.5%
Multiple votes are allowed.
  1. V1518599131776
    Cupcake Feb 14, 2018
    Narenso likes this.
  2. N1518605012096
    N1518605012096 , Feb 14, 2018 :
    same issue with my phone. by the latest update of oxygen it's creates issue in sound system even it is not ringing on side ring slide.
  3. Narenso
    Froyo Feb 14, 2018
    Narenso , Feb 14, 2018 :
    Yes in my Oneplus 5. It's annoying. Team please fix this asap.
  4. N1518605012096
  5. the98kid
    Ice Cream Sandwich Feb 14, 2018
  6. Narenso
    Froyo Feb 14, 2018
    Please update if the default ringtone works !!
  7. quantized
    quantized , Feb 14, 2018 :
    i faced exact same issue. volume settings were high and alert switch was in sound mode but no sound until i restar5ed.
    inalso found camera opening blank or almost black and the only cure was a restart.
    disappoijted with oreo update
  8. Narenso
    Froyo Feb 14, 2018
    Deepan5333 likes this.
  9. Siddharth_Jm
    Siddharth_Jm , Feb 14, 2018 :
    even i was facing the same issue. clear cache storage and reboot the device. issue will be resolved.
  10. S1518606205306
    S1518606205306 , Feb 14, 2018 :
    same with me too after the new software update I am not able to hear SMS and notifications ringtone..I can hear caller tones
    please support this issue
    Narenso likes this.
  11. mallikbadam
    mallikbadam , Feb 14, 2018 :
    looks like a bug in Oreo update from Google I have similar problem on my Oneplus5T and Nexus phone when I use custom ringtone.
    Check if you are using a local ring tone, switch to the preloaded ring tones till this is fixed
  12. Harish_7
    Eclair Feb 14, 2018
  13. OALEXANDER
    Assistant Head Moderator Assistant Head Moderator Feb 14, 2018
    OALEXANDER , Feb 14, 2018 :
    Merged
    idkwhoiam322 likes this.
  14. D1518608594729
    D1518608594729 , Feb 14, 2018 :
    am also facing same problem after update ..
    notification sounds not working properly after reboot it's works but it's temporary again am facing same problem
  15. Kishanlr
  16. ssrakesh
    ssrakesh , Feb 14, 2018 :
    incoming calls or messages sounds are not working though ringer volume is high. i need to reboot the phone every time to make it work.
    Could you please look into this immediately?
  17. Intruder71
    Lollipop Feb 14, 2018
    Intruder71 , Feb 14, 2018 :
    Shame you didn't"look in to it" as you could have saved a pointless post ...
  18. xyZZu
    Eclair Feb 14, 2018
  19. vinodt168
    vinodt168 , Feb 14, 2018 :
    After the Oreo update I was facing the same issue.
    Reboot helped me in sound functioning again.
    There should be a permanent fix from OnePlus, or else it doesn't make sense using a OnePlus mobile which doesn't notify through sounds.
  20. hpsauce37
    Gingerbread Feb 14, 2018
