52
Sound [MEGA THREAD] No ring on "ring mode" also.
Problem with sound notification
  1. How to fix the issue
    36 vote(s)
    97.3%
  2. any third party app?
    2 vote(s)
    5.4%
Multiple votes are allowed.
  1. Q1518326211522
    Donut Feb 11, 2018
    Q1518326211522 , Feb 11, 2018 :
    yeah I found the solution for this ,
    if it product is one plus 5t please check to your top left of your phone where you can see a alert slider. if this alert slider is completely down then you can get your phone ringing . jus check this.make sure the alert slider is completely down.
  2. damu Reddy
    Cupcake Feb 11, 2018
    damu Reddy , Feb 11, 2018 :
    thanks it worked for me
    Q1518326211522 likes this.
  3. Waveform Modifier
    Marshmallow Feb 11, 2018
    Waveform Modifier , Feb 11, 2018 :
    Some had problems but most of us are fine. You can search the forum if there is solutions. (use the web site and not the app)
  4. psk7177
    Gingerbread Feb 11, 2018
    psk7177 , Feb 11, 2018 :
    good to hear that, but you said your slider is not working.
    good to explore for atleast aday or 2.to explore.the.phone and then post
  5. Q1518326211522
    Donut Feb 11, 2018
    yeah it was a bit harder. but every one is facing the same issues
    many of them don't know that this alert slider has three slides on the top left side of the phone . I have raised the complaint and told the solution to it as soon as I identified it.
  6. Q1518326211522
    Donut Feb 11, 2018
    on top left side , above the volume button . you people will find an alert slider which should be dragged completely down if you want your receiving calls to ring.
  7. Ayee
    Ayee , Feb 11, 2018 :
    hi am not able to set local ringtone ,if I set local ringtone it just vibrates but no sound.help me on this
  8. psk7177
    did u copy your ringtones to Ringtones folder ?
    if so then select and.choose the tone, also check if you have changed the alert slider to ring(completely down)
  9. Android450
  10. J1516880140461
  11. G_Nuveen_Shurma_RpJH
  12. Ayee
    thank you now working...
  13. T1518332343981
    Donut Feb 11, 2018
    T1518332343981 , Feb 11, 2018 :
    same issue no ring just vibrating..fixes once i restart my mobile but again the issue continue.. please fix this issue.
  14. sun ads media
    sun ads media , Feb 11, 2018 :
    dear team I have problem to set a rig tone once we put new rig tone it's not riging phone was silent when calls cumming.. may we select one pluses phone rig tone it's working kindly help me and we instt new apps some rig tones that's also not set for rig tone that's say memericard not shown
    F_Khushboo_Singh_NiCD likes this.
  15. sun ads media
  16. F_Khushboo_Singh_NiCD
    sun ads media likes this.
  17. G_nani_hemanth_oTxQ
  18. nikki544
  19. Melron
    Melron , Feb 11, 2018 :
    m also facing the same problem. ones I reboot my phone it works normal. but then again repeats the same problem.
  20. nikki544
    nikki544 , Feb 11, 2018 :
    yeah right dear.....same here
