156
[MEGA THREAD]OP5/T Battery/Heating Issues and Tips: Share Your Stats & How To Improve Battery Life !
  1. Sudeep reddy v
    Cupcake Feb 11, 2018
  2. MartiRutllant
    MartiRutllant , Feb 11, 2018 :
    Maybe it's just because oreo is noticing better what's draining battery than nougat.. But idk, in nougat screen was most of the percentage
  3. B1514900966419
    Gingerbread Feb 11, 2018
    B1514900966419 , Feb 11, 2018 :
    I think Google had fixed this through OREO 8.1 upgrade. I have heard this draining issue from users of other devices on OREO 8.0 but not heard about the same reported by users of Pixel or Nexus devices. So, assuming that an upgrade to the latest version might fix the problem
  4. izzykasha
    Lollipop Feb 11, 2018
    izzykasha , Feb 11, 2018 :
    it's more likely rubbish apps draining the phone overnight 4-5% seems normal anything above this do some housekeeping on your phone's.
    they do need care and attention or they become sluggish and slow
  5. E1518281039549
  6. kryshnakishore
    Ice Cream Sandwich Feb 11, 2018
    kryshnakishore , Feb 11, 2018 :
    irrespective of android version, battery drain is mainly becoz of apps you use & its background running state...check privacy guard & manage
  7. B1514900966419
    Agreed, but it could be the system apps as well which is causing the issue. User apps can anyways can be cleaned from memory. Might be it's the system apps which is causing the issue which has been fine tuned in the new version.
  8. B1514900966419
    With very new upgrade/update Google does bring in new feature, stability and performance improvement s. The monthly security updates bring in lot of improvement' s to the OS
  9. NeverGiveUpOnUrDreams
    vamsi020 likes this.
  10. Deepukabali
    Eclair Feb 11, 2018
    Deepukabali , Feb 11, 2018 :
    bro first see screen usage time within 5hrs the battery drain 27%
  11. Sudeep reddy v
    Sudeep reddy v , Feb 11, 2018 :
    it's ok thats fyn , going down to 10% u get up to 6½ - 7 hrs
  12. B1514900966419
    remember for very app that is running there is a PID which is created and the process keeps running in the background draining battery and utilizing RAM as well. The default sys apps keep running in the background even if you use any tool to clean the memory and close apps.
  13. nitishram
  14. Mr_DJ
  15. sunny.anand
  16. T1514915009883
    T1514915009883 , Feb 11, 2018 :
    it's same for me after Oreo update. my phone doesn't last for a day which used to be 2 days before Oreo update. I hope OP does something to correct this.
  17. B1514900966419
    no, I don't agree. Nothing is perfect in the first attempt and that is why you get 7.0, 7.1, ......
    upgrades and same would be the case with 8.0, 8.1, ...
  18. ksc10165
  19. Vasudevudu
    Froyo Feb 11, 2018
    Vasudevudu , Feb 11, 2018 :
    Yes, I'm also observed same with the last night. previously it was draining about 1% per 3 hours but now Oreo update it's draining 1% per 1 hour.
  20. Azeeb_IND
    Arsath1994 likes this.
