154
[MEGA THREAD]OP5/T Battery/Heating Issues and Tips: Share Your Stats & How To Improve Battery Life !
  1. U1521419491577
    Cupcake Mar 19, 2018
    U1521419491577 , Mar 19, 2018 :
    Hi, anyone facing battery drain as well in idle mode? My phone status is 8.0 Oreo with dual sim card but signal work fine, i have off the data and wifi during over night, but it still drop almost 8~10% for 7hours, is it normal? And i fojnd out my phone wifi connection speed were slower than other brand phone, anyway to solve?
  2. Arjun V Ajay
    Arjun V Ajay , Mar 19, 2018 :
    U1521419491577
    Hi, anyone facing battery drain as well in idle mode? My phone status is 8.0 Oreo with dual sim card but signal work fine, i have off the data and wifi during over night, but it still drop almost 8~10% for 7hours, is it normal? And i fojnd out my phone wifi connection speed were slower than other brand phone, anyway to solve?​
    no that's not a normal drain It should only drain max of 3%
    or try using greenify and also turn on doze mode and aggressive doze mode
  3. U1521419491577
    Thanks for your reply, but greenify need to root right? How to use the doze mode?
  4. Arjun V Ajay
  5. U1521419491577
    Thanks, for the doze mode is turn on from the greenify apps? Anyways do u know what cause the wifi connection speed slow for 5t as compare with other device were running smoothly
  6. Arjun V Ajay
    i didn't notice any slowdown on my wifi but you factory reset and clear the cache and then check the speeds
  7. U1521419491577
    I just did a clear cache, but if don't use factory reset is it ok? Because all the data and apps was in my phone.
  8. Anand_Sagar18
    Jelly Bean Mar 19, 2018
  9. Slash1909
    Gingerbread Mar 19, 2018
    Slash1909 , Mar 19, 2018 :
    Look for OnePlus weather app in the Play store.
  10. Slash1909
    Pretty good battery performance with a mix of battery saver and daytime usage.
    I rarely let the battery go below 70%. I'm not a heavy user.
  11. Mohit7850
    Mohit7850 , Mar 19, 2018 :
    The battery is draining faster then what it used to. I've had this problem since the last update
    Please roll out a fix for this.
  12. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Mar 19, 2018
    NeVeR_SeTTLe , Mar 19, 2018 :
    After the update, did you try to wipe cache from Recovery?
  13. Mohit7850
    Did that.
  14. NeVeR_SeTTLe
  15. Mohit7850
    NeVeR_SeTTLe likes this.
  16. G_T_Bennett
  17. G_T_Bennett
  18. Arjun V Ajay
    no iam not complaining but this sot is with battery saver, doze and aggressive doze mode ON so the changes will vary when this is TURNED off
  19. F1511521922766
  20. nsvenkatas
