154
[MEGA THREAD]OP5/T Battery/Heating Issues and Tips: Share Your Stats & How To Improve Battery Life !
  1. vinvik88
    Cupcake Mar 20, 2018
    vinvik88 , Mar 20, 2018 :
    After my recent update, my settings show Android version 8.0 and Oxygen os version 5.0.4. Since this update my battery is draining quicker even if I do not use any apps or listen songs or check mail. When I use Google maps the battery starts to drain even quicker. This was not the case before the update. Even if I use Google maps my battery used to stick longer.
    Will the one plus team release any patch for this fix? Has anyone raced such an issue recently after updating their oxygen os?
    I am using one plus 5T.
    shadehuntsman likes this.
  2. T1521557017398
  3. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Mar 20, 2018
    NeVeR_SeTTLe , Mar 20, 2018 :
    Did you try wiping the cache from Recovery after the update?
  4. vinvik88
    I cleared the cache after update but still face the problem. I even uninstalled apps like fb, all the games but no improvement in battery life though
  5. F1514500987105
  6. NeVeR_SeTTLe
    Try to factory reset your device. OnePlus stated that after a major Android version update, factory reset is recommended.
  7. vinvik88
    will give a try. thanks for the suggestion.
    NeVeR_SeTTLe likes this.
  8. pablofg1978
    Head Moderator Head Moderator Mar 20, 2018
    pablofg1978 , Mar 20, 2018 :
    Thread merged
  9. H1519548376884
    Gingerbread Mar 20, 2018
    H1519548376884 , Mar 20, 2018 :
    want to give a feedback upon the update for battery life.
    if next update can improve the battery life then it will be awesome.
    i wish next update fixes every issue on battery and we get the backup as we used to get on the nougat version.
  10. pablofg1978
    Thread merged
  11. B1521571084914
    B1521571084914 , Mar 20, 2018 :
    My phone is getting heated up without any reason. There is no app load or charger connected to the phone.
  12. NeVeR_SeTTLe
    Can you post your battery stats and also your temperature stats?
  13. B1521571084914
  14. Shehzaad91
    Donut Mar 20, 2018
    Shehzaad91 , Mar 20, 2018 :
    today I was watching a movie on my 5T when it suddenly got heated and was really very hot to hold... I'm facing this issue from past 1 week but it was slightly hot unlike today...
    is anyone else facing the same issue?
    B1521571084914 likes this.
  15. NeVeR_SeTTLe
    There is an app called Ampere. Download it from Google Play Store and then post it here.
  16. B1521571084914
    yeah man same
  17. B1521571084914
    I will test but tell me if this app checks the overall performance of the battery? because right now my phone is not hot or is it like I have to check via app when it heats up?
  18. B1521571084914
  19. NeVeR_SeTTLe
  20. B1521571084914
    actually what I think when I put my cover on phone it heats up .. otherwise it won't happen.
