115
[MEGA THREAD]OP5/T Battery/Heating Issues and Tips: Share Your Stats & How To Improve Battery Life !
  1. G_T_Bennett Jelly Bean Apr 19, 2018
  2. mcinnet1 Cupcake Apr 19, 2018
    mcinnet1, Apr 19, 2018 :
    yes
  3. VANdaVAN Cupcake Apr 19, 2018
  4. MakaraCTG Donut Apr 19, 2018
    MakaraCTG, Apr 19, 2018 :
    Try use your phone at least 2-3 cycle charge. Use it until it's hit 3-5% then charge it to 95% and stop it! Android system is learning how you use your phone to maintain the battery power on what apps you're using the most and when you need it the most. My OP5T 1st I updated to 8.1 my phone with 98% can use only 4:35 hr SOT but after few cycle charge is upto 6hr heavy use.
  5. ten_piseth Eclair Apr 19, 2018
  6. DJCHAUHAN99 Gingerbread Apr 19, 2018
  7. pablofg1978 Spanish POC Assistant Head Moderator Apr 19, 2018
    pablofg1978, Apr 19, 2018 :
    Thread merged
  8. Gav_W86 Starting Point Expert Apr 19, 2018
    Gav_W86, Apr 19, 2018 :
    the question asked can't be answered with "yes"...
  9. pablofg1978 Spanish POC Assistant Head Moderator Apr 19, 2018
    Thread merged
  10. mcinnet1 Cupcake Apr 19, 2018
    nothing changed..it's a sudden issue
  11. R1524144855419 Cupcake Apr 19, 2018
  12. shahbaj alam Gingerbread Apr 19, 2018
    shahbaj alam, Apr 19, 2018 :
    well, using my 5T with oos 5.1 , battery life has been degraded. I'm using it for last 2 days and difference is visible. i know it sound weird, but will it be a good idea to roll back to open beta 6??
    your thoughts guys???
    O1520145267007 likes this.
  13. Gav_W86 Starting Point Expert Apr 19, 2018
    Boot the phone into recovery mode and clear the cache.
    1. Power off phone.
    2. Power on phone whilst holding down the volume down button (this takes slightly longer to react than you would expect and after the initial splash screen goes blank for a slightly un-nerving amount of time. But just wait).
    3. Enter the PIN/Password you use to unlock the phone when prompted.
    4. Choose a language.
    5. Choose "Wipe data and cache" (don't worry this is only a path to a submenu, it won't delete your data).
    6. Choose "Wipe cache" (IMPORTANT - MAKE SURE YOU DON'T TAP ERASE EVERYTHING).
    7. It will confirm that you have selected clear cache and ask you to say YES.
    8. When it says success choose "Reboot"
  14. Gav_W86 Starting Point Expert Apr 19, 2018
    1. Power off phone.
    prat_brat likes this.
  15. J1518962871790 Froyo Apr 19, 2018
  16. pablofg1978 Spanish POC Assistant Head Moderator Apr 19, 2018
    Thread merged
  17. Dextro_619 Honeycomb Apr 19, 2018
    Dextro_619, Apr 19, 2018 :
    I am just 5hrs 33mins battery life on OnePlus 5T after the 8.1 update .I was getting 7hrs of battery life before on same amount of usage .
  18. Daan_Eekhofアニメ Jelly Bean Apr 19, 2018
    Dextro_619 likes this.
  19. astracd Honeycomb Apr 19, 2018
    astracd, Apr 19, 2018 :
    I agree... clean cache... and do few charges ... full - empty - full - empty - full... Then see how it will perform...
    I still think 6h+ on screen time is decent, especially is screen brightness is higher. Not sure what people expect.
    Dextro_619, I_am_Batman and Budruel like this.
  20. Johnathan Wick Honeycomb Apr 19, 2018
    Johnathan Wick, Apr 19, 2018 :
    People expect 2 days on screen time [e]1f602[/e]
    astracd and Budruel like this.
