156
[MEGA THREAD]OP5/T Battery/Heating Issues and Tips: Share Your Stats & How To Improve Battery Life !
  1. superplus
    Head Moderator Head Moderator Dec 10, 2018
    superplus , Dec 10, 2018 :
    Please have a look at the Terms & Rules and seek assistance in one of the many existing threads (check out the tips thread too). Duplicate thread merged.
    Artemus. likes this.
  2. Udaya_Chendur
    Honeycomb Dec 17, 2018
    Udaya_Chendur , Dec 17, 2018 :
    Am using OnePlus 5 since its launch and it has been great. Recently updated to OB 22 and liking the taste of pie.
    In the past month, I noticed a drop in the battery back up. I used to get 5hrs to 5.30hrs of SOT.
    Now am getting only around 4hrs.
    Just wanted to check the battery health. Any suggestions?
    How about geekbench?
  3. G_ramcybertech_intelugu_
    Cupcake Dec 19, 2018
    G_ramcybertech_intelugu_ , Dec 19, 2018 :
    i m already cleared but no use
  4. JayaDasari
    Donut Dec 19, 2018
    JayaDasari , Dec 19, 2018 :
    What's the screen brightness level you use?
    I use around 50% brightness and getting 4 hours SOT since a week. Earlier with same usage pattern I was getting 5.5 to 6 hours. I have a 5T
  5. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Dec 19, 2018
    NeVeR_SeTTLe , Dec 19, 2018 :
    As everybody is telling you, your screen brightness might be high or you use the phone a lot.
    If you want to be really sure, download Wakelock Detector [Lite] to see if you have any apps that are sucking your battery in the background and if there are, uninstall those apps and install alternatives or freeze the apps.
  6. Ashenmx
    Froyo Dec 19, 2018
    Ashenmx , Dec 19, 2018 :
    8 hour screen on time is definitely not bad. Its great. Have you had more than 8 hour screen on time before?
  7. Darshil_Raichura
    Honeycomb Dec 19, 2018
    Darshil_Raichura , Dec 19, 2018 :
    I am also facing same issue
    actually you are having a great SOT but same is not the case with me.
    Sunddenly in 5-7 days battery has started draining very fast, i don't understand why.
  8. Waveform Modifier
    Marshmallow Dec 19, 2018
    Waveform Modifier , Dec 19, 2018 :
    See the pinned battery thread.
  9. Mukund760
    Ice Cream Sandwich Dec 20, 2018
    Mukund760 , Dec 20, 2018 :
    Well I recently updated to 5.1.7 and.... yeah Battery life certainly has degraded.
    P.S. I Fully Formatted my device after the update and have already done battery calibration. Doesn't work. Seems like OP messed up something with the update.
  10. Mukund760
    I just realised that out 8 cores 4 of the high performance cores never go to sleep(they are never stopped) and the 4 low powered cores doesn't go lower than 518Mhz while the 4 high performance cores(which should be stopped when there is no high intensity task) cannot go lower than 806Mhz. won't it utilize more battery if they are always running. What's the point of having 4 efficient core and 4 high performance core if they are going to always stay active. Can someone Explain?
  11. Mukund760
    here's the pic of CPUZ.
  12. PokiX
    Jelly Bean Dec 20, 2018
    PokiX , Dec 20, 2018 :
    Charging stats!
    The phone is on with screen off. Running on OB21.
    From 1% to 60%: 30mn. Up to 100%: 1h35mn.
    OB20:
  13. Sarfaraz Ansari13
    Donut Dec 21, 2018
    Sarfaraz Ansari13 , Dec 21, 2018 :
    Hey guys!
    Back from 3-4 days I'm noticing that my phone is getting charged from 15 to 100% under an hour. And it's discharging as fast from before.. Previously it used to take around 1.25 hours to charge.. Any suggestions or tips would be helpful. I already did factory reset but to no avail..
  14. Himanshu0000608
    Ice Cream Sandwich Dec 26, 2018
    DC11 likes this.
  15. DC11
    Eclair Dec 26, 2018
    Himanshu0000608 likes this.
  16. B_Wrath
    Nougat Dec 26, 2018
  17. DC11
    Eclair Dec 26, 2018
  18. Himanshu0000608
    DC11 likes this.
  19. DC11
    Eclair Dec 26, 2018
  20. camohan
    Moderator Moderator Dec 26, 2018
