122
[MEGA THREAD]OP5/T Battery/Heating Issues and Tips: Share Your Stats & How To Improve Battery Life !
  1. Oneplusshutterbug Gingerbread May 28, 2019
    G1559553306049 likes this.
  2. Oneplusshutterbug Gingerbread May 28, 2019
    Oneplusshutterbug, May 28, 2019 :
    check the temperature by using third party apps if it raises from 50deg then u need a prior service
  3. H1516205410330 Cupcake May 30, 2019
    H1516205410330, May 30, 2019 :
    Oneplusshutterbug
    check the temperature by using third party apps if it raises from 50deg then u need a prior service​
    Is this normal? Taken with CPUZ right after a call. Everything goes well except when I call over GSM
  4. G1533109230823 Cupcake May 30, 2019
    G1533109230823, May 30, 2019 :
    Draining of battery is not an issue in my OP 5t... I am charging my device once a day & its last upto night..
    sathishselvaraj likes this.
  5. UpputuriMahesh Eclair May 30, 2019
    UpputuriMahesh, May 30, 2019 :
    I did same but still loosing battery life didn't use much only youtube WhatsApp don't where its using battery
  6. Ashik_Zaman Eclair May 30, 2019
  7. X1556090279093 Cupcake May 31, 2019
  8. C1520910424093 Froyo May 31, 2019
  9. Oneplusshutterbug Gingerbread Jun 1, 2019
    Oneplusshutterbug, Jun 1, 2019 :
    yup! that's not an issue
  10. R1528608020186 Cupcake Jun 2, 2019
    R1528608020186, Jun 2, 2019 :
    hi please help me connect my phone via Bluetooth to my Bluetooth headset and my car..Unable to do so for the last 15 days.
  11. Ashik_Zaman Eclair Jun 2, 2019
    Ashik_Zaman, Jun 2, 2019 :
    r u on beta?
  12. Aziz_Amin_Oneplus Jelly Bean Jun 2, 2019
    Aziz_Amin_Oneplus, Jun 2, 2019 :
    Check your location and Network Signals, Location would be on with Improved accuracy turn it off and if you are going where signals are poor then turn off mobile data as it will drain mobile network standby.
    Herbert_Lagos likes this.
  13. O1559543077680 Cupcake Jun 3, 2019
    O1559543077680, Jun 3, 2019 :
    Hello guys i would like to ask if its normal for bnew op5t drainy for 1st time? or its defective? i already update with oxygen 9.0.5. Please give me some advice tia.
  14. Oneplusshutterbug Gingerbread Jun 3, 2019
    Oneplusshutterbug, Jun 3, 2019 :
    usage days?
  15. O1559543077680 Cupcake Jun 3, 2019
  16. Oneplusshutterbug Gingerbread Jun 3, 2019
    that's not an issue it might be using a lot background data
    please do check everything n restart!
  17. O1559543077680 Cupcake Jun 3, 2019
    so it needs more calibration for battery? and uncheck those settings that using a lot of background data?
  18. Oneplusshutterbug Gingerbread Jun 3, 2019
    yes! u have to reset them
  19. aykut39 Honeycomb Jun 7, 2019
    aykut39, Jun 7, 2019 :
    try resetting all apps permission.. (you may loose some data but it is not important compared to the benefit)
    it is more efficient if some app causes unexpected behavior..
  20. sabbir_shawon Cupcake Jun 9, 2019
    sabbir_shawon, Jun 9, 2019 :
    recently my op5 i face an issue like device temparature is too low and battery temperature is -40° so i replace my battery but now i face same issue my battery charge stuck in different % like 70%,40%,60% but charge decrease internally...my dash charger not working perfectly..it connect with device for charge but after sometime it disconnect from device...anyone have solution pls help me...my luck is so bad cause there is no service center of oneplus in my country...so pls help me if anyone face this issue... 1560100293747.jpg
