122
[MEGA THREAD]OP5/T Battery/Heating Issues and Tips: Share Your Stats & How To Improve Battery Life !
  1. the_o2 Marshmallow Jul 3, 2019
    the_o2, Jul 3, 2019 :
    Do a factory reset once if possible
    Babai@1 likes this.
  2. Babai@1 Cupcake Jul 3, 2019
    Babai@1, Jul 3, 2019 :
    Once i have done it, 1-2 it goes well but again it happens.
  3. the_o2 Marshmallow Jul 3, 2019
    Then it definitely caused by some app which is running in background
  4. Babai@1 Cupcake Jul 3, 2019
    I have even seen that, but suddenly it starts heating, while turning off it comes to normal temp.
  5. the_o2 Marshmallow Jul 3, 2019
    Better to contact to the app developer then
    Babai@1 likes this.
  6. Oreo2201 Froyo Jul 4, 2019
    Oreo2201, Jul 4, 2019 :
    I'm getting Dash Charge issues, phone shows the usual Red Pulse Light, on connecting Dash Charger.
    It takes few seconds to show Dash Charging.
    When I pick up my phone, it disconnects from charge and again reconnects showing red pulse.
  7. Abhi.bhandral Gingerbread Jul 4, 2019
    Abhi.bhandral, Jul 4, 2019 :
    How much your are getting from your op5 after 2 yrs, I'm thinking of getting new battery for OP5..!!
    headhunteryaseen likes this.
  8. G1563806804135 Cupcake Aug 7, 2019
    G1563806804135, Aug 7, 2019 :
    I bought my OnePlus 5t off eBay in July 2019. the battery lasts
    basically all day and I love it, very satisfied with the battery life..
  9. G1563806804135 Cupcake Aug 7, 2019
  10. headhunteryaseen Eclair Aug 7, 2019
    headhunteryaseen, Aug 7, 2019 :
    excatly dude..I bought my op5t before 2yrs and it's time to change new battery for my phone
    G1563806804135 likes this.
  11. G1563806804135 Cupcake Aug 7, 2019
  12. headhunteryaseen Eclair Aug 7, 2019
    noice...well about ur op5 ? and it's battery life
  13. G1563806804135 Cupcake Aug 7, 2019
    absolutely fantastic, I can use it all day at work. dash charge on the the drive home and I'm good to go.
  14. headhunteryaseen Eclair Aug 7, 2019
    that's great well my battery life sucks on my op5t I do Play pubg very aggressive on my device
    U1528245230413 likes this.
  15. U1528245230413 Eclair Aug 8, 2019
    U1528245230413, Aug 8, 2019 :
    Hey Guys. I am facing rapid battery drain in the last couple of days. with 30 % battery left when I went to sleep (Of course data off and mobile was in silent mode) and I found it dead. Yes. battery drained completely and it got switched off. Rebooted and charged to 100% and got only 4 hours sot. Did twice. With similar usage, I would end up with 6 - 7 hours SOT usually. I read those pinned post couple of months ago and increased my SOT to 7 hours. Always I charge from 10 to 100% in a single stretch. Actually I noticed that my SOT was gradually decreasing from 7 hours and now I'm in between 3 to 4 hours in a week. What am I missing still? Can anyone guide? Aandd It's OP6. 13 months old. TIA!
  16. javi95ing Eclair Aug 12, 2019
    javi95ing, Aug 12, 2019 :
    hi guys, I don't think this is a good battery performance,what do you guys think? wifi scanner off and adaptive brightness off
  17. H1519548376884 Gingerbread Aug 12, 2019
  18. B1514900966419 Gingerbread Aug 12, 2019
    B1514900966419, Aug 12, 2019 :
    clear cache and storage of Google Play services and restart your phone
  19. H1519548376884 Gingerbread Aug 12, 2019
    H1519548376884, Aug 12, 2019 :
    didn't worked...its still on
  20. B1514900966419 Gingerbread Aug 12, 2019
    it would show up, but the usage percentage will reduce or stop. Charge your phone to 90% or above and then remove it charging, use it for sometime and check battery stats again
