124
[MEGA THREAD]OP5/T Battery/Heating Issues and Tips: Share Your Stats & How To Improve Battery Life !
  1. J_Duece_81
    Froyo Aug 14, 2019
    J_Duece_81 , Aug 14, 2019 :
    I noticed in the screen shots that "Play Services" is not being optimized nor can you disable background usage. Are you able to change either of these settings at all. I'm still using Oreo 8.1 and if I start having problems with "Play Services" acting up I shut it off.
  2. B1514900966419
    Gingerbread Aug 14, 2019
    B1514900966419 , Aug 14, 2019 :
    Play services is part of GAPPS and you can't modify any settings unless you root the phone
  3. Magno Souza 18
    Cupcake Aug 14, 2019
  4. J_Duece_81
    Froyo Aug 14, 2019
    I guess they changed that for Android 9, I'm still on Oreo 8.1 , no root. However, if I turn off Play Services some apps may not work right because they are dependant on Play Services for things like location data and other stuff. My post wasn't a solution, just more of an observation. Hopefully the previous poster can resolve the issue of 2 Play Services entries by clearing cache and or data for Play Services. If that doesn't help then you've got to figure out which app is causing the issue.
  5. H1519548376884
    H1519548376884 , Aug 14, 2019 :
    is it only me...
    or...
    that second one is a clone!
  6. J_Duece_81
    Froyo Aug 14, 2019
  7. Cervantes
    Lollipop Moderator Aug 14, 2019
    Cervantes , Aug 14, 2019 :
    Hi
    The battery thread is a thread of questions and/or commentary
    Please, You read the first post
    Post moved
  8. Dnesh1092
    Donut Aug 15, 2019
    Dnesh1092 , Aug 15, 2019 :
    Thank you for this useful thread. I referred to op and tried following the steps given still my 5t has battery drain. Since I like the features of pie, don't want to rollback to Oreo.
    Just sharing my battery stats from yesterday. really hope we get out of play services battery drain.
  9. Laamapalmu
    Jelly Bean Aug 15, 2019
  10. Pantelist Triantafillidis
    Cupcake Aug 15, 2019
  11. C1566030746370
    Cupcake Aug 17, 2019
    C1566030746370 , Aug 17, 2019 :
    Benim telefon Özel pil kalibrasyon sonrası en yüksek ekran açık kalma süresi 9 saat 11 dk.! (hiç bir kısıtlama yok)
    Kalibrasyon : Güvenli mod'da ful şarj sonrası en az 1.5 saat şarjda kalacak sonra pil tamamen tüketilecek (tel.açılamayacak kadar) kapalıyken full şarj dolduktan sonra en az 1.5 saat bekleme, tel açılıp full şarjda 1 saat beklenecek..
  12. vinay 5t
    Gingerbread Aug 19, 2019
    vinay 5t , Aug 19, 2019 :
    can anyone help me to replace the battery of my op5t
    as i saw in website it 1125 rs in india but is there any one to help ,what is the totally charged to replace in india ...? i am from Hyderabad
  13. R1548932885379
    Cupcake Aug 19, 2019
    R1548932885379 , Aug 19, 2019 :
    Hi in last 2 update of oneplus 5 both feature is very good and very useful espically zen mode but there is a issue that after last 2 update which cover (screen recorder and zen mode feature) on my one plus 5. Battery draining fast, timing reduce from 24 hrs to 16 hrs with same usage like before update my phone. can any one help me out to resolve this issue.
  14. haRiHaRRy
    Cupcake Aug 20, 2019
    haRiHaRRy , Aug 20, 2019 :
    After the update of Android patch 2019.8. battery is draining faster than usual
  15. RDavik
  16. Herbert_Lagos
    Jelly Bean Aug 20, 2019
    Herbert_Lagos , Aug 20, 2019 :
    In English please. This is an international forum
  17. B1549857206369
    Cupcake Aug 21, 2019
  18. E1518281039549
    Cupcake Aug 23, 2019
  19. Aciel
    Donut Aug 23, 2019
    Herbert_Lagos likes this.
  20. draguz95
    Eclair Aug 28, 2019
