134
[MEGA THREAD]OP5/T Battery/Heating Issues and Tips: Share Your Stats & How To Improve Battery Life !
  1. happyhaps
    Froyo Nov 19, 2019
  2. Waveform Modifier
    Marshmallow Nov 19, 2019
  3. happyhaps
    Froyo Nov 19, 2019
    happyhaps , via OnePlus 5T , Nov 19, 2019 :
    i was asking about downgrading the OS. do i need to do something more than downloading the big os and flashing through recovery?
  4. Waveform Modifier
    Waveform Modifier , Nov 19, 2019 :
    Why do you need to downgrade your OS? Pretty sure it's not the fault of the OS. Because outside of WhatsApp draining my battery, everything is fine. Can't blame the OS for an app issue.
  5. happyhaps
    Froyo Nov 21, 2019
  6. Vinayak Murari
    Donut Nov 21, 2019
  7. toruvinn
    Froyo Nov 23, 2019
    toruvinn , via OnePlus 5 , Nov 23, 2019 :
    Whatsapp seems not to be a problem for me anymore, however... Since the last update I've noticed battery in my mi band draining very fast. I'm not sure how many people remember this, but last December I believe we had a similar update that tweaked something with BT in the phone, that made my band battery drain by like 20% per day (normally it's closer to 4%), presumably by making the phone communicate with it all the time for some reason. This time it looks similar, although the drain isn't that bad (still much higher than normally). This also manifests with Android OS battery usage being top on the phone (much higher than screen usage, too). So, what kind of "improvements" did that last oxygen update have, and does anyone else notice that higher battery usage on their paired BT devices? Perhaps only with the low power BT ones.
  8. F_Raghav_Sharma_TAgq
    Cupcake Nov 24, 2019
    F_Raghav_Sharma_TAgq , Nov 24, 2019 :
    worst experience after it's update battery draining too much , start hanging . I think it's more than 4-5 months there is no new update I think they stop their support to 5T customers
  9. camohan
    Marshmallow Moderator Nov 24, 2019
    camohan , Nov 24, 2019 :
    Thread merged. The last update was in October 2019, I am not sure which update are upon on. If you are on beta update, it has stopped and was announced as well.
    For battery thing, it is important that you provide more details if you are seeking for solution.
  10. F_Raghav_Sharma_TAgq
  11. F1513220400351
    Froyo Dec 4, 2019
    F1513220400351 , via OnePlus 5T , Dec 4, 2019 :
    Hello Everyone,
    From last one month Battery is getting low frequently, at ideal mode it is consuming more than 20% at night when mobile data and wifi is Off.
    it is happening after latest update of whatsapp where they introduced fingerprint feature or. after lastest update of one plus.
    does anyone also facing battery issue ?
    dhavalpatel7 and Vinayak Murari like this.
  12. dhavalpatel7
    Donut Dec 28, 2019
    dhavalpatel7 , Dec 28, 2019 :
    Anyone faced something like this before? You have more than 50% of battery and suddenly you see a blank screen and you had to plug in the charging cable and it starts charging from 0%?
  13. dhavalpatel7
    Donut Dec 28, 2019
    I do experiencing the same problem.
    F1513220400351 likes this.
  14. João Carlos Chande
    Gingerbread Jan 14, 2020
  15. G_pankaj_mishra_zUjq
    Donut Jan 14, 2020
    G_pankaj_mishra_zUjq , Jan 14, 2020 :
    hi , my phone battery is draining quickly and charging issue with cable dash charger in one plus 5t please resolve this issue give some update to resolve this issue ....
    João Carlos Chande likes this.
  16. stark2991_PL
    KitKat Jan 15, 2020
  17. G_pankaj_mishra_zUjq
    Donut Jan 15, 2020
  18. stark2991_PL
    KitKat Jan 15, 2020
    stark2991_PL , Jan 15, 2020 :
    Check what is draining the battery then.
  19. amanpreetdhir
    Cupcake Jan 21, 2020
  20. mdvant
    Cupcake Jan 22, 2020
    mdvant , Jan 22, 2020 :
    same problem here... I hardly get throught a day without charging the phone.
