154
[MEGA THREAD]OP5/T Battery/Heating Issues and Tips: Share Your Stats & How To Improve Battery Life !
  1. McJader
    Marshmallow Apr 3, 2021
    McJader , Apr 3, 2021 :
    Try this:?
    Turn off the device.
    Press and hold Power button.
    Tap Restart.
    When the device is restarting, press the Volume Down and Power buttons simultaneously.
    When the device logo appears, release the Power button and continue to press the Volume Down.
    If you see Safe Mode in the lower-left corner after the device restart, Safe Mode is on, otherwise you need to repeat the process.
  2. johnykes
    Donut Apr 3, 2021
    johnykes , via OnePlus 5T , Apr 3, 2021 :
    Tried it, but it takes me somewhere where I can just install things from storage, clear stuff or reboot. No safe mode option.
  3. McJader
    I thought so.
    You can't see the safe mode option using this method:
    Please try again.
  4. pablofg1978
    Head Moderator Head Moderator Apr 3, 2021
    pablofg1978 , Apr 3, 2021 :
    Thread merged
  5. johnykes
    Donut Apr 3, 2021
    thank you but wtf man? the thread you merge mine into it's old af and my problem started today. I can't see any link between the threads. I guess I can sell my phone for 10 bucks now
  6. johnykes
    Donut Apr 3, 2021
    I found it, but the problem persists in safe mode too.
  7. pablofg1978
    Hello there,
    Please read and follow the forum rules
  8. Y1619018406756
    Cupcake Apr 21, 2021
  9. Deep.jat
    Cupcake Apr 22, 2021
  10. Deep.jat
  11. G_Терентий_Не
    Cupcake May 8, 2021
  12. Pelajar
    Cupcake May 20, 2021
    Pelajar , May 20, 2021 :
    In my case the battery drains real quick despite of following the tips provided here.
    but my bigger problem is phone will immediately switch off off when battery is under 50% battery capacity, and if I try to turn it back on, it'll tell me that battery is completely drained.
    but when I charge, it'll start charging from 20-30-40% depending on where the phone switched off.
    not sure what I can screenshot here.
    H1512062085641 likes this.
  13. Sai Ram Roy
    Cupcake Jun 11, 2021
    Sai Ram Roy , Jun 11, 2021 :
    While charging the adapter is also very heating than before.
    And takes wifi alot of battery due to reconnecting for long hours huff....🤨🙁🙃
  14. H1512062085641
    Gingerbread Jun 25, 2021
  15. H1512062085641
    H1512062085641 , via OnePlus 5T , Jun 25, 2021 :
    Same with me
  16. Pelajar
    Cupcake Jun 25, 2021
    Pelajar , Jun 25, 2021 :
    So in my case, it was due to a defective replacement battery. I've changed the battery again, now happy times...
