158
[MEGA THREAD]OP5/T Battery/Heating Issues and Tips: Share Your Stats & How To Improve Battery Life !
  1. MostakimShohan
    Donut Oct 9, 2021
    MostakimShohan , via OnePlus 5T , Oct 9, 2021 :
    Over 3 days I can't use my phone . When I called someone my ear speaker going heart . And my voice don't listening property. When i look my battery use ditalis I see google play services take my meximum battery power. I done factory reset. All kind of rest. But nothing changed anything. Plz help .
  2. pablofg1978
    Head Moderator Head Moderator Oct 9, 2021
    pablofg1978 , Oct 9, 2021 :
    Thread merged
  3. Skullzrulerz
    Cupcake Oct 10, 2021
    Skullzrulerz , Oct 10, 2021 :
    Good afternoon
    I have currently got a OnePlus 5T that I have used for nearly four years
    However as of recently I have noticed that it's getting quite warm if not hot at times, but it only seems to happen when I'm using Chrome or Social Media like Facebook or Instagram.
    What could I do to somehow fix this issue or any advice that I could have?
    Many thanks.
  4. Barani daran
    Eclair Oct 11, 2021
    Barani daran , via OnePlus 5 , Oct 11, 2021 :
    While charging the phone the percentage numbers for the charging doesn't increase (if I put in 32 percentage means after an hour of charging it remains the same 32,but it doesn't comes down from 32 after few hours of using the mobile).So please kindly help me with solutions to resolve this..
    Thank you
  5. cbuckley101
    Cupcake Oct 11, 2021
    cbuckley101 , Oct 11, 2021 :
    Hi,
    For the past 2 weeks the battery on One Plus 5T has been draining within 3 or 4 hours following a full charge. I have actually been using my phone less than normal as well. The battery is also heating up at random points too.
    Is this a common issue at the moment? Is there an update coming?
    I know there was issues before with a Android's covid tracking notifications so I have disabled this but does not seem to help.
    I have had my phone for 4 years, could this be a natural decline in battery performance?
  6. Photographyeyecatching
    Gingerbread Oct 11, 2021
    Photographyeyecatching , via OnePlus 5 , Oct 11, 2021 :
    Today i have noticed a major problem in my mobile happening 1st time..
    Today i kept my mobile on a table for whole day. And noticed that my mobile is heating and battery is draining automatically..
    I haven't used my mobile even for a minute. It was 100% in morning 8 am. And when i checked on 12 pm it was 20%. And temperature was high too
    How is this possible?
    MostakimShohan and G_Nabil__uZHn like this.
  7. pablofg1978
    Head Moderator Head Moderator Oct 11, 2021
    pablofg1978 , Oct 11, 2021 :
    Thread merged
  8. G_Nabil__uZHn and MostakimShohan like this.
  9. Hari1994
    Cupcake Oct 12, 2021
    G_Nabil__uZHn likes this.
  10. herohl
    Froyo Oct 13, 2021
    herohl , Oct 13, 2021 :
    thanks for ur info, on my OP5 never heat and drain battery again, after force stop and disable Google Search App.
  11. G_Nabil__uZHn
    Cupcake Oct 13, 2021
    G_Nabil__uZHn , Oct 13, 2021 :
    Je rencontre un problème dans mon téléphone OnePlus 5t le problème de chauffage de la batterie
  12. picazin
  13. smmunavar
    Cupcake Oct 15, 2021
    smmunavar , Oct 15, 2021 :
    my device battery is draining very quickly to 1% and going on power off and on. I am using dual sim in my device.
  14. pablofg1978
    Head Moderator Head Moderator Oct 15, 2021
    pablofg1978 , Oct 15, 2021 :
    Thread merged
  15. SUDIP5GHORAI
    Froyo Oct 24, 2021
    SUDIP5GHORAI , via OnePlus 5T , Oct 24, 2021 :
    my oneplus 5t battery is draining like rain...in 30 min 100% to 15% and it's heating like a frying pan for 1 month...Is there any issues with the update of any app or something ..please fix it...@OnelusIndia
  16. N1597441269770
    Cupcake Oct 24, 2021
    N1597441269770 , via OnePlus 5T , Oct 24, 2021 :
    Hi All,
    I have seen some issues with my phone, since September update of Google app. The phone overheats and the app consumes too much battery.
    There is a workaround which is uninstalling updates of the Google app from play store, but this has to be done every few days since the app will try to update automatically even if auto updates are off
    This seems to be an issue with multiple devices not only One plus, google is aware of this issue and I decides to create this post to ask if someone else on OP5T is experiencing the same issue.
    Thanks!
  17. pablofg1978
    Head Moderator Head Moderator Oct 24, 2021
    pablofg1978 , Oct 24, 2021 :
    Thread merged
    N1597441269770 likes this.
  18. Ranjithpraba
    Cupcake Oct 25, 2021
  19. C1591019479056
    Cupcake Oct 27, 2021
    C1591019479056 , via OnePlus 5T , Oct 27, 2021 :
    Dear Team
    I M Using An OnePlus 5T.Phones Battery Is Draining At A Faster Rate .Is It Some Bug Or Update Required For The Same To Control The Battery Decreasing .
    Need A Solution As A Continuous Charge Is Not Possible For The Same.
  20. pablofg1978
    Head Moderator Head Moderator Oct 27, 2021
    pablofg1978 , Oct 27, 2021 :
    Thread merged
    Your device is EOL, there will be no more updates
