122
[MEGA THREAD]OP5/T Battery/Heating Issues and Tips: Share Your Stats & How To Improve Battery Life !
  1. Phi_ Honeycomb Jan 21, 2018
  2. Leb96 Gingerbread Jan 21, 2018
  3. TheFifeFlyer Froyo Jan 21, 2018
    T1514757614114 likes this.
  4. svvenn Ice Cream Sandwich Jan 21, 2018
    svvenn, Jan 21, 2018 :
    It's because of all the location google does. Here's my tip: turn off location history, go to google app settings and put it on data saver, go maps settings and turn off traffic notifications.
    With this I quadrupled my standby time.
  5. tomeklives Froyo Jan 21, 2018
    tomeklives, Jan 21, 2018 :
    Am I wrong in noticing that all the phones except the two OnePlus phones have the bluetooth on. The OnePlus have it off!
  6. T1514757614114 Froyo Jan 21, 2018
    T1514757614114, Jan 21, 2018 :
    as I see, you use the phone very intense - GPS+camera+turned on screen barley all the time (6-7 hours).. as I can see, you got a lot of notifications (mb social networks, or SMS), that eats your battery. so the question is - WHAT DO YOU WANT FROM YOUR POOR DEVICE BATTERY? lol.
    but really strange thing that your device using GPS and camera simultaneously. this is very strange. check your apps.
    1. check your apps that works in background. turn off that u don't need them.
    2. check apps, that use your phone in background.
    3. turn on advanced battery power management
    4. use your phone untill it's turned off, get in recovery menu and clear cache, than power up your phone up to 100 percent.
    do the step 4 once per month to calibrate your battery.
  7. Leb96 Gingerbread Jan 21, 2018
  8. frkngmsr60 Eclair Jan 21, 2018
  9. T1514757614114 Froyo Jan 21, 2018
    Leb96
    What about mine battery? Its okay?
    I think it's ok.
    there are so many things that draining your battery:
    1 screen brightness - the main drainer
    2 poor wifi or mobile signal. the type of mobile data (2g is the most light drainer, 4g is most heavy drainer), switching between 2g, 3g, 4g frequently in case of bad signal area is drain your battery so quickly.
    3 apps in background (your case) that backup something, indexing something etc.
    4 apps, that use cpu, GPU like games.
    5 cache trash after apps for firmware upgrades that needs to wipe (battery controller errors that appears frequently on all devices)
    this is mine statistics. 5t. 20 hours working at least, and 13 hours in buffer
  10. G_Ermal_Stublla_ihrj Gingerbread Jan 21, 2018
  11. T1514757614114 Froyo Jan 22, 2018
    frkngmsr60 likes this.
  12. frkngmsr60 Eclair Jan 22, 2018
    frkngmsr60, Jan 22, 2018 :
    i think too, 5t is incredible
  13. G_Steven_Heaps_OEUQ Cupcake Jan 22, 2018
    G_Steven_Heaps_OEUQ, Jan 22, 2018 :
    Anyone having issues with battery drain overnight disconnecting from 5ghz wifi band seems to work.
    Anyone care to post their battery use per hour with screen on, apps like accubattery averages have me at 12.1% per hour with screen on 1.9% screen off.
    So getting about 3:30 to 4 hours SOT but I'm off wifi most of the day
  14. T1514757614114 Froyo Jan 22, 2018
    T1514757614114, Jan 22, 2018 :
    try to calibrate battery. use your phone untill it's turned off, then recovery menu, wipe cache, power up your phone untill 100 percent.
    do this every month.
  15. pablofg1978 Spanish POC Assistant Head Moderator Jan 22, 2018
  16. Shivam_sakral Honeycomb Jan 22, 2018
    Shivam_sakral, Jan 22, 2018 :
    dattry drain 100% to 92% in just 7 or less minutes but works fine after 92%
    also delete all apps but no results
    Divakar_Reddy likes this.
  17. Gnawd Honeycomb Jan 22, 2018
  18. Shivam_sakral Honeycomb Jan 22, 2018
  19. Gnawd Honeycomb Jan 22, 2018
    Gnawd, Jan 22, 2018 :
    Try rebooting the phone or you can replace the battery. Most likely a faulty battery
    Shivam_sakral likes this.
  20. i.am.mr.shersha Froyo Jan 22, 2018
    i.am.mr.shersha, Jan 22, 2018 :
    No it won't.
