112
[MEGA THREAD] OP5T Battery/Heating Issues and Tips: Share Your Stats & How To Improve Battery Life !
  1. AnubhavVandkar Honeycomb Dec 8, 2018
    AnubhavVandkar, Dec 8, 2018 :
    It doesn't matter when you've charged your phone just check your screen on time. Having 6 hours itself is very good I can't see anything to complain.
    You just used your phone too much on that day your phone can't be on for 24 hours can it
  2. chswoei1974 Eclair Dec 8, 2018
  3. praveengnk Donut Dec 8, 2018
    praveengnk, Dec 8, 2018 :
    after the update and cache clean this is what battery status , can anyone help pls
    pls suggest ....
  4. FeelTheSky Eclair Dec 8, 2018
    ezzkht likes this.
  5. G_Maze_Hyde_JbOb Gingerbread Dec 8, 2018
    paulomodesto and borft like this.
  6. Mukund760 Honeycomb Dec 8, 2018
    Mukund760, Dec 8, 2018 :
    G_Maze_Hyde_JbOb
    8h Screen on Time is good! so what Problem Are you trying to explain us?​
    I think that 9 hrs of SOT is incorrect. It happens when you partially charge your phone again and again. The SOT of all those partial charges add up instead getting reset for every charge.
  7. Mukund760 Honeycomb Dec 8, 2018
    here is mine
    but its due to partial charging. It doesn't show for a single charge
    aanishjangra likes this.
  8. Herbert_Lagos Jelly Bean Dec 9, 2018
    Herbert_Lagos, Dec 9, 2018 :
    The SOT should in fact be between 6 to 8 hours, ob iously depending on how heavily you use your phone. If I use a lot camera app always on brightest screen level, the SOT will be closer to 6h.
    So there's nothing to worry except if you keep always connected on wifi, data connexion, Whatsapp, or heavy games..... Then there is nothing to di as these are high battery consumers.
  9. benkb Cupcake Dec 9, 2018
    benkb, Dec 9, 2018 :
    9 hours screen on timeand u say that battery is draining.
    BTW lower screen brightness if u want more screen on time.
  10. M1542826182121 Cupcake Dec 9, 2018
    M1542826182121, Dec 9, 2018 :
    I had this problem, and I am very light user, about 1 hour of screen time per day. Before the upgrade I would get about 36 -40 hours on a charge, after the upgrade, 6 hours.
    Oneplus arrange an online session to downgrade my phone back to 5.1.5.
    This has solved the battery drain, but now I have the Bluetooth instability issue in the car which I didn't have before!
  11. superplus English POC Assistant Head Moderator Dec 10, 2018
    superplus, Dec 10, 2018 :
    Please have a look at the Terms & Rules and seek assistance in one of the many existing threads (check out the tips thread too). Duplicate thread merged.
    Kytharsis likes this.
  12. udayachendur Honeycomb Dec 17, 2018
    udayachendur, Dec 17, 2018 :
    Am using OnePlus 5 since its launch and it has been great. Recently updated to OB 22 and liking the taste of pie.
    In the past month, I noticed a drop in the battery back up. I used to get 5hrs to 5.30hrs of SOT.
    Now am getting only around 4hrs.
    Just wanted to check the battery health. Any suggestions?
    How about geekbench?
  13. G_ramcybertech_intelugu_ Cupcake Dec 19, 2018
    G_ramcybertech_intelugu_, Dec 19, 2018 :
    i m already cleared but no use
  14. JayaDasari Donut Dec 19, 2018
    JayaDasari, Dec 19, 2018 :
    What's the screen brightness level you use?
    I use around 50% brightness and getting 4 hours SOT since a week. Earlier with same usage pattern I was getting 5.5 to 6 hours. I have a 5T
  15. NeVeR_SeTTLe The Lab - OnePlus 6 Reviewer Dec 19, 2018
    NeVeR_SeTTLe, Dec 19, 2018 :
    As everybody is telling you, your screen brightness might be high or you use the phone a lot.
    If you want to be really sure, download Wakelock Detector [Lite] to see if you have any apps that are sucking your battery in the background and if there are, uninstall those apps and install alternatives or freeze the apps.
  16. Ashenmx Eclair Dec 19, 2018
    Ashenmx, Dec 19, 2018 :
    8 hour screen on time is definitely not bad. Its great. Have you had more than 8 hour screen on time before?
  17. Darshil_Raichura Honeycomb Dec 19, 2018
    Darshil_Raichura, Dec 19, 2018 :
    I am also facing same issue
    actually you are having a great SOT but same is not the case with me.
    Sunddenly in 5-7 days battery has started draining very fast, i don't understand why.
  18. Waveform Modifier Lollipop Dec 19, 2018
    Waveform Modifier, Dec 19, 2018 :
    See the pinned battery thread.
  19. Mukund760 Honeycomb Dec 20, 2018
    Mukund760, Dec 20, 2018 :
    Well I recently updated to 5.1.7 and.... yeah Battery life certainly has degraded.
    P.S. I Fully Formatted my device after the update and have already done battery calibration. Doesn't work. Seems like OP messed up something with the update.
  20. Mukund760 Honeycomb Dec 20, 2018
    I just realised that out 8 cores 4 of the high performance cores never go to sleep(they are never stopped) and the 4 low powered cores doesn't go lower than 518Mhz while the 4 high performance cores(which should be stopped when there is no high intensity task) cannot go lower than 806Mhz. won't it utilize more battery if they are always running. What's the point of having 4 efficient core and 4 high performance core if they are going to always stay active. Can someone Explain?
