95
[MEGA THREAD] OP5T Battery/Heating Issues and Tips: Share Your Stats & How To Improve Battery Life !
  1. kishori02 Gingerbread Dec 31, 2017
    kishori02, Dec 31, 2017 :
    auto sync location gps ambient display is off? n u r using dark theme??
  2. G_Nikhil_Prasad_ Cupcake Dec 31, 2017
    G_Nikhil_Prasad_, Dec 31, 2017 :
    Yes, all are off and using dark theme along with a dark wallpaper.
  3. kishori02 Gingerbread Dec 31, 2017
    my every 1 % giving almost 10 mins
  4. G_Nikhil_Prasad_ Cupcake Dec 31, 2017
  5. F_Luis_Ehrt_TiBA Froyo Dec 31, 2017
  6. camohan Lollipop Moderator Dec 31, 2017
  7. kishori02 Gingerbread Dec 31, 2017
  8. camohan Lollipop Moderator Dec 31, 2017
    camohan, Dec 31, 2017 :
    Because there is already a thread to share the stats.
  9. kishori02 Gingerbread Dec 31, 2017
  10. georgebower1 Froyo Dec 31, 2017
    georgebower1, Dec 31, 2017 :
    Hi guys these are my stats.
    I'm using dark theme and I'm using a dark wall paper, i did have ambient display turned on i will turn that off after reading here.
    bluetooth and wifi scanning off. location, bluetooth and nfc all turned off unless needed.
    any tips on how i can improve on these at all please? seeing some people getting insane screen on time and I'm getting nowhere near it
  11. kishori02 Gingerbread Dec 31, 2017
    where is ur stats
  12. georgebower1 Froyo Dec 31, 2017
  13. kishori02 Gingerbread Dec 31, 2017
  14. pgrey Gingerbread Dec 31, 2017
    pgrey, Dec 31, 2017 :
    @georgebower1 You've got a TON of apps that (by default) are going to pull background data, LOTS of it, FB, Twitter, Instagram, whatsapp, snapchat, etc...
    These won't always get accurate percentage reporting, IME, so where they look like they're drawing say 7%, they might be pulling more like 10-15%, which is significant (Oreo finally seems to be getting a little better at tracking background, maybe).
    Personally, I think OP has a problem on the 5T anyway, with accurately reporting discharge/charge, mine jumps all over, in "chunks", like today where my phone went from 81-82%, then to 92%, and then to 100%, with basically nothing in-between (I was checking it every minute or so, to make sure I wasn't just perceiving things).
    This combination isn't good for tracking things.
    Either way though, you need to restrict background data on all those social apps, or decide you're just okay with a higher drain-rate.
    One thing to consider too, is that these apps change over time, and sometimes go from being a low-moderate-user to being a moderate-high user (of battery AND data).
    If you look at your data for these apps, it can be "revealing", because you'll see the big percentages of background.
    georgebower1 likes this.
  15. polys Froyo Dec 31, 2017
    polys, Dec 31, 2017 :
    Seriously, people getting 7+ hours of SOT with 20% left and asking how to improve when some of us barely get 5-6h
  16. kishori02 Gingerbread Dec 31, 2017
  17. Tcat007 Donut Jan 1, 2018
    Tcat007, Jan 1, 2018 :
    I have yet to get UNDER 8 hrs SOT, 10.5 was max. I do have airplane mode and WiFi on 95 % of my day, and WiFi off at night. I sync apps, contacts, calendar, Gmail and keep. No battery drainers like FB app. GPS mode very seldom. Mainly use Chrome, Telegram, G+, Gmail, and lots of CC Saga. I'm on beta Oreo.
    phil57 likes this.
  18. robinsc Gingerbread Jan 1, 2018
    robinsc, Jan 1, 2018 :
    I charge nightly ,with heavy gaming I have managed to bring the battery down to 18 percent. overall battery is pretty good
  19. rohitcraju Eclair Jan 1, 2018
  20. Kwinonwplus Eclair Jan 1, 2018
    Kwinonwplus, Jan 1, 2018 :
    I feel that the battery is amazing when in airplane mode even while watching movies.
    But when 4g data is on, there is a drastic change.
    The standby time difference like overnight 6to 8 percent loss.
