3
Display MEMC chip in Netflix
  1. J1586890308394
    Cupcake Jun 18, 2020
    J1586890308394 , Jun 18, 2020 :
    Still not working for me either... Some days it works, some days it doesn't.. The MEMC should have some sort of Hard control like a pop-up notification saying "You want to start the MEMC for this content?" or something like that in my opinion..
    When you get the automatic service to work on is own, sometimes it doesn't recognise that you are on, lets say, Netflix, and it simply doesn't start..
    In my opinion, is a software issue that Oneplus should fix..
  2. Venky101
    Froyo Jun 18, 2020
  3. Jose_Lizarazo
    Gingerbread Jun 25, 2020
    Jose_Lizarazo , Jun 25, 2020 :
    With the latest Netflix update, still not working.
    I hope they can revert back whatever change they did in order to make it work again.
    :rolleyes:
  4. T1593073692058
    Donut Jun 27, 2020
    T1593073692058 , Jun 27, 2020 :
    Netflix version : 7.61.0
    Firmware : 10.5.9
    Motion graphics smoothing not working for me , any update on this?
  5. Jose_Lizarazo
    Gingerbread Jul 1, 2020
    Jose_Lizarazo , Jul 1, 2020 :
    Unfortunately not, and I have been keeping the updates here, but it seems that sometimes works with some versions of Netflix and sometimes it doesn't.
    :mad:
    sarabaz likes this.
  6. sarabaz
    Eclair Jul 11, 2020
    E1587459749968 likes this.
  7. Jose_Lizarazo
    Gingerbread Jul 12, 2020
    Jose_Lizarazo , Jul 12, 2020 :
    It's a shame is not working, but for me, I have another problem right now and is that Widevine passed from L1 to L3 with no reason; I'm waiting the next update to see if this fixes the problem.
    :confused:
  8. ExterminalPT
    Froyo Jul 12, 2020
    ExterminalPT , Jul 12, 2020 :
    Now u can try to factory reset your device with MsmDownloadTool and after that update your device to oxygen OS 10.5.10. It will fix your problem.
  9. iambittu007
    Cupcake Jul 19, 2020
    iambittu007 , via OnePlus 8 Pro , Jul 19, 2020 :
    At first it worked on my mobile in every app including Netflix,it was awesome but after update 10.5.11 it stopped working on Netflix,please give me a solution
  10. Jose_Lizarazo
    Gingerbread Jul 21, 2020
    Jose_Lizarazo , Jul 21, 2020 :
    It's not about update or factory reset, since sometimes is working with certain Netflix versions and sometimes it doesn't.
    Is not only about the updates, but also Netflix needs to have this compatibility as well.
    :confused:
  11. Jose_Lizarazo
    Gingerbread Jul 28, 2020
    Jose_Lizarazo , Jul 28, 2020 :
    I updated to the latest Netflix update from today and now is working again.
    Let's hope Netflix people won't break it again.
    :p
    ExterminalPT likes this.
  12. ExterminalPT
    Froyo Jul 28, 2020
    ExterminalPT , Jul 28, 2020 :
    I can confirm,
    It works now. Hope wont break it again.
  13. Venky101
    Froyo Jul 29, 2020
  14. Jose_Lizarazo
    Gingerbread Aug 6, 2020
  15. Venky101
    Froyo Aug 6, 2020
  16. luckychauhann
    Donut Oct 2, 2020
  17. luckychauhann
    Donut Oct 16, 2020 at 7:12 PM
