memory storage is showing full
  1. moiyusuf
    Cupcake Sep 7, 2018
    moiyusuf , Sep 7, 2018 :
    Thanks this solved the issue. Apparantly i had 90 gb in this recycle bin. Can't oneplus delete these files ??
  2. Wombo2016
    Donut Sep 14, 2018
    Wombo2016 , Sep 14, 2018 :
    Just for future reference you can also go to the Gallery app and clear data as long as you have backed up.
  3. lucans7
    Cupcake Oct 30, 2018
    lucans7 , Oct 30, 2018 :
    Worked for me. Doing that cleared about 30GB on my disk! Kudos!
  4. Katie_Rourke_Dowding
    Cupcake Nov 9, 2018
    Katie_Rourke_Dowding , Nov 9, 2018 :
    Nope, still have identical issue after following these steps.
  5. G_Sarah_Khalid_skmq
    Donut Nov 10, 2018
    G_Sarah_Khalid_skmq , Nov 10, 2018 :
    Hi, so I found something weird on my phone. I was trying to figure out why Others was taking up so much space, I opened DCIM and it says 10GB but when I open the folder and select all the files it says they're only 700MB or so. :/ I tried all the steps above to clear the memory but to no avail. Please help.
  6. naresh4561
    Cupcake Dec 29, 2018
    naresh4561 , Dec 29, 2018 :
    This helped solve the issue for me. Thanks
    W1513805504680 likes this.
  7. andreidre77
    Cupcake Jan 6, 2019
    andreidre77 , Jan 6, 2019 :
    Thanks a lot I just had a similar issue and I fixed it thanks to you.
    Cheers!
  8. Neezum
    Eclair Jan 23, 2019
    Neezum , Jan 23, 2019 :
    Hi guys!
    Found a fix for me. Seems like the folder in my pictures gallery for the "Deleted Files" were taking up so much of my internal memory. Try deleting all the files in your "Deleted Files" in photos and videos gallery to free up some huge amount of space.
    Cheers!
  9. G_Matej_Arnold_sOqw
    Cupcake Jan 25, 2019
  10. ckdeena
    Cupcake Feb 16, 2019
    ckdeena , Feb 16, 2019 :
    If you have recently deleted you media, camera photos/ video, social media photos or videos. Then you have to go to gallery and clear the recently deleted folders. That was the issue in my case.
  11. A_Sai_Ganesh_7989
    Eclair Feb 18, 2019
    A_Sai_Ganesh_7989 , Feb 18, 2019 :
    now a days it's common we see it in all Android phones .. clear the logs bcoz the unwanted dumps stores in smartphone... being using Whatsapp the status logs stores more data that would be invisible in phone but.. when you connect to PC you would probably see that.. might this information help you
  12. vijeeshthayyil
    Cupcake Mar 26, 2019
    vijeeshthayyil , Mar 26, 2019 :
    This helps me, i found telegram using more space and its not even traced anywhere , as all files where hidden.
    G_Sneackers_UA_cVtx likes this.
  13. vikramavinash
    Cupcake Apr 23, 2019
    vikramavinash , Apr 23, 2019 :
    Thanks for your suggestion. It resolved memory issue in my 1+3T. Now Memory usage is showing 17% from 99%.
    Thanks a lot [e]1f44d[/e]
  14. Ghostyy
    Cupcake May 5, 2019
    Ghostyy , May 5, 2019 :
    Another suggestion to those using Face Unlock.
    Every time you unlock your phone using your face it stores a 400kb file, these files all build up and within 3 days the folder that stores these showed as 2GB on my 1+5
    In File manager > Internal Storage find FaceUnlockDebug and delete all the files in the folder. (Do not delete the folder, may cause unseen issues)
  15. FeroOAS
    Cupcake Aug 1, 2019
    FeroOAS , Aug 1, 2019 :
    thanks a ton buddy! i kept deleting images and was still sitting at 1% and with deleting from the recycle bin i have 11% free, wow..amazing! what i dont understand is that when i go to the memory option it shos the gallery under images and also under others and files, how does gallery occupy space in all the 3 categories, i am sure that the same images are not accoupying 3 times the space. pls advise.
  16. Arpr
    Cupcake Aug 31, 2019
  17. ChrisNeo
    Eclair Nov 14, 2019
    ChrisNeo , Nov 14, 2019 :
    My problem was the OnePlus switch app.
    I forgot that i made a 32Gb backup but under the storage it was showing 32Gb of images. Screenshot_20191114-214525.jpg Screenshot_20191114-214537.jpg
  18. Rocking_Yash
    Donut Nov 21, 2019
    Rocking_Yash , Nov 21, 2019 :
    I have issue with my storage from last 2 week, i was cleaning cach file everyday and uninstall many apps, but everyday it shows storage is running out of space. Can anyone help me with this. In my OP3T. Before 2 weeks i had 20 GB free space.
    #38
  19. M1540185655958
    Cupcake Dec 5, 2019
    #39
  20. V1576035923453
    Cupcake Dec 11, 2019
    #40
