memory storage is showing full
  1. V1576035923453
    Cupcake Dec 11, 2019
    V1576035923453 , via OnePlus 6 , Dec 11, 2019 :
    i have the same problem for last few months. now almost i had cleaned it. you may see my screen shot where images shows 33GB. but actually i have less than 500 Mb images only. Even if i drill down to internal storage, i dont find the space occupied by anything else
    3rd screen shot is the actual photos i have in my camera folder
    #41
  2. Paschfire
    KitKat Dec 11, 2019
    Paschfire , via OnePlus 3T Gunmetal , Dec 11, 2019 :
    Empty the Recycling bin for all your G Photos/Gallery Apps.
    #42
  3. Swap76
    Cupcake May 29, 2020
    Swap76 , May 29, 2020 :
    This worked for me thanks
    #43
  4. T1598701820632
    Cupcake Aug 29, 2020
    T1598701820632 , Aug 29, 2020 :
    I bought a One plus 7T in June 2020
    The 256 GB variant
    But within 2 months, the internal storage is showing as 228 GB occupied although I have data only worth some 11-12 GB
    Plz help with regards to that
    I have researched and found that people have raised this similar complaint over excessive memory issues
    #44
  5. B1577513793093
    Cupcake Sep 26, 2020
    B1577513793093 , Sep 26, 2020 :
    #45
  6. X1602747360558
    Cupcake Jan 13, 2021
    X1602747360558 , Jan 13, 2021 :
    Nothing to worry,simple go to the file manager>Internal Storage>Show Hidden files...By deleting these files i reduced my storage from 124gb to 49gb.
    #46
  7. G_Lauri_zWWG
    Cupcake Feb 9, 2021
    G_Lauri_zWWG , Feb 9, 2021 :
    Same. Allmoast new oneplis nord. It has 300 + pictures and couple of videos, very little apps downloaded, and it shows 71 gb used. I'v went trough alll the floders and apps and all and there is nothing
    #47
