137
Mental support group for (ROM) flashaholics
  1. KforHorizon
    KitKat Feb 26, 2017
    KforHorizon , Feb 26, 2017 :
    Which ROM? Why are you trying this?
    theshinybeast likes this.
  2. theshinybeast
    Marshmallow Feb 26, 2017
    theshinybeast , Feb 26, 2017 :
    Why? What ROM? Do you not have TWRP installed?
    I have only ever fastboot flashed a factory image. Just use TWRP.
  3. theshinybeast
    :rolleyes: Is this not incredibly old school? And I don´t believe a zip file can be flashed this way?
  4. KforHorizon
    KitKat Feb 26, 2017
    It won't work, but still! I want to know the reason behind trying that!
  5. theshinybeast
    So did I,:rolleyes: found this o_O
  6. KforHorizon
    KitKat Feb 26, 2017
  7. theshinybeast
  8. The Imp
    Ice Cream Sandwich Feb 26, 2017
    The Imp , Feb 26, 2017 :
    Spammers:eek:
    theshinybeast and KforHorizon like this.
  9. KforHorizon
    KitKat Feb 26, 2017
  10. Bakr
    Honeycomb Feb 26, 2017
    Bakr , Feb 26, 2017 :
    that's why
  11. Bakr
    that's where I got the link from
    I think it's my only option :|
  12. theshinybeast
    If you can boot into fastboot you should be able to boot into recovery, adb reboot recovery
    check out this thread and make sure
    you have the right drivers installed https://forums.oneplus.net/threads/...lashing-recovery-roms-kernels-rooting.291274/
    If the worst comes to the worst you can follow
    Point 2. Recovering from no OS installed and no access to TWRP, fastboot does work.
    Edit: An idea , you could reflash TWRP and then enter your recovery by typing fastboot boot and press spacebar, then drag the twrp_x.x.x.x.img into the same command window right after flashing.
    Bakr likes this.
  13. KforHorizon
    KitKat Feb 26, 2017
    If what @theshinybeast has told you, doesn't work! You should flash the fastboot images of CyanogenOS and then go from there!
  14. theshinybeast
    Lol:D thus point 2 of Dax's guide. But that of course it means he'll lose all data. I would try to flash twrp again and boot into TWRP first and if that didn't work flash the fastboot images.Probably wrong but.....:rolleyes:
  15. KforHorizon
    KitKat Feb 26, 2017
    No.. If he doesn't want to lose all his data, he shouldn't type the userdata command, and he won't lose his data!
  16. theshinybeast
    Damn, forgot about that.So then he should just go for it.
    KforHorizon likes this.
  17. KforHorizon
    KitKat Feb 26, 2017
    Yes he should if he can't boot into recovery from fastboot!
  18. Bakr
    I thought adb only works in recovery and when os is booted
    I will try it and I will let you know what happens
    thanks!
  19. theshinybeast
    It might not work but if it doesn't try to flash TWRP and boot directly into recovery the way I explained. If worse comes to worse flash the fastboot image of Cyanogen. There's a link in the thread I linked and all the commands as well.
    Bakr likes this.
  20. Bakr
    Honeycomb Feb 27, 2017
    Bakr , Feb 27, 2017 :
    THIS WORKED!! thank you!
    I wiped system cache and dalvik cache then flashed the rom.zip but sadly it got stuck on a bootloop :mad: any ideas why? (is it because I wiped system? :|)
    I will try your method again to enter recovery but do I need to reflash TWRP again?
    after that I will try flashing the latest rom.zip with open gapps.
