3
Menu not working for Oneplus X
  1. prem3300
    Donut Feb 6, 2016
    prem3300 , Feb 6, 2016 :
    Hello,
    From yesterday my oneplus X is showing some problem. As soon as I press the menu button from the home screen, the menu opens and than the phone is automatically directed to home screen.The menu opens and disappears and than the phone is again on the Homescreen. Can anyone please tell me why it is happening
    xxcczz1, Guidoce and gdrt94 like this.
  2. Thanasis Kalatheris
    Eclair Feb 6, 2016
    Thanasis Kalatheris , Feb 6, 2016 :
    Dude delete the 2nd thread u have created 2 threads for this. Wiping the launcher's data or uninstalling the launcher (if ur one Google now launcher or any other third party launcher ) didn't work for you?
  3. prem3300
    Donut Feb 6, 2016
    I don't use third party launcher. What should I do now
  4. piogliwi
    Donut Feb 6, 2016
    piogliwi , Feb 6, 2016 :
    Turn off hiding the search bar in settings
    MaximeLibert likes this.
  5. ivisalvarado
    Cupcake Feb 6, 2016
    ivisalvarado , Feb 6, 2016 :
    I'm having the same issue, every time i try to open menu it keeps sending me back to recent apps. This is since las update
  6. yogenderSingh1
    Honeycomb Feb 6, 2016
    arungk1 likes this.
  7. haree
    Donut Feb 6, 2016
    haree , Feb 6, 2016 :
    hi
    do this i had the same problem now solved
    settings>apps>launcher>wipecache, delete data.u need to go in to all apps and see the launcher and do it
    thanks to AlexVendettA @ XDA Forum
  8. Beta_Tester
    Cupcake Feb 6, 2016
    Beta_Tester , Feb 6, 2016 :
    The error occurs with me after every reboot. When I go to "hide searchbar" and disable it again it works.
  9. haree
    Donut Feb 6, 2016
    hi
    i also have a feeling that hiding the search bar give us this problem because after doing as i said above the problem came again now let me see and un hide the search bar will seee what happens and come back on this
  10. Sainadh994
    Cupcake Feb 7, 2016
    Sainadh994 , Feb 7, 2016 :
    Same thing is going on my phone. What should I do now??
  11. haree
    Donut Feb 7, 2016
    haree , Feb 7, 2016 :
    hi
    now after bringing back the search bar things seems to be fine hope the problem dosnt come again actually im fine with this launcher dont want to use any other
  12. manoj091187
    Cupcake Feb 10, 2016
    manoj091187 , Feb 10, 2016 :
    For me as well i had same issue and i turned off hide search bar and problem got resolved......but i feels its the work around not a fix.........ONE PLUS please look into this.
  13. rahulchandak
    rahulchandak , Feb 10, 2016 :
    But after reboot it again go back to recent screen.NOT RESOLVED.
  14. KrSuraj
    KrSuraj , Feb 10, 2016 :
    Having the same problem since yesterday.Did a reset but the problem pops up again. Enabling touch in developer options shows pressure (in red) at some coordinates, event when screen is not in contact with anything. Are you guys getting the same result?
    San2Sreshta likes this.
  15. haree
    Donut Feb 11, 2016
    haree , Feb 11, 2016 :
    hi
    guys just enable the google search bar on home screen and ur problem will be solved i had the same problem.hid the bar for some time got the problem again.Now i have un hidden the seach bar on home screen no problem it has been working fine for me .Just try the same hope it solved the problem for too
  16. RamziNzigou
    Cupcake Feb 11, 2016
    RamziNzigou , Feb 11, 2016 :
    It works but it's not a solution to the problem. As it was said before, it's just a work around and OnePlus should fix this.
  17. Goggeboy
    Honeycomb Feb 11, 2016
    Goggeboy , Feb 11, 2016 :
    Come on, everybody knows it's a work around but it works, until we get a new update, that maybe fix the problem. Cheers
  18. haree
    Donut Feb 11, 2016
    he he may be we just sell this on flipcart as they are giving crazy exchange prices for the 1st ann of them and moto together just kidding guys i like this phone too much its too sexy and my wife will kik my A** if i get it changed this time Ha ha ha
  19. Yaswanth35
    Cupcake Feb 12, 2016
    Yaswanth35 , Feb 12, 2016 :
    Hi guys my one plus x launcher is not responding due to this suddenly my pone hangs up with black screen and every time I have to reboot the phone it is happening frequently. Please help me anyone
  20. San2Sreshta
    Gingerbread Feb 12, 2016
    San2Sreshta , Feb 12, 2016 :
    Try to toggle the Google search bar on home page,.... Go to settings by long pressings wallpaper of your home screen, ->settings with wrench symbol the switch the Google search bar..
