message at restart
  1. Heredea_Nathanael
    Cupcake Apr 15, 2019
    Heredea_Nathanael , Apr 15, 2019 :
    Hello everyone,
    I have a message when I restart my OnePlus 3T is there someone with the same message?
    you can see the message in the picture
    thank you for your support
  2. Neddard
    Lollipop Apr 15, 2019
    Heredea_Nathanael likes this.
  3. Heredea_Nathanael
  4. athaarv
    Jelly Bean Apr 15, 2019
    athaarv , Apr 15, 2019 :
    Your bootloader's clearly unlocked and you've somehow seemed to have triggered DM-Verity
    xnutzii likes this.
  5. Heredea_Nathanael
    yeah ai understand that but how do I locked again
  6. athaarv
    Assuming you have experience in rooting and flashing custom ROMs, I'd recommend using the MSM Download tool to flash your device back to stock, a.k.a. the Unbrick tool. If not, simply contact OnePlus via live chat and they'll remotely host a session with you and flash your device for you. Don't forget to make a full backup of everything as your device will be completely wiped during the process.
    Vansh99 and JoeBar07 like this.
  7. Paschfire
    KitKat Apr 15, 2019
    Paschfire , Apr 15, 2019 :
    The same way you unlocked it, using ADB/Fastboot via terminal prompt.
    code:
    fastboot oem lock
    Though, if you've modified your devices /System partition in any way I suggest you flash stock OOS 5.0.X and perform a factory reset before doing so.
    Vansh99 likes this.
  8. Paschfire
    KitKat Apr 15, 2019
    You could also root the device by flash magisk v19, or flash a custom kernel, to bypass DM-Verity.
    TWRP custom recovery is required to perform these actions.
  9. athaarv
    Yeah I wouldn't recommend that tbh. Much safer to stick to the MSM Download tool if you wanna lock the bootloader
    JoeBar07 likes this.
  10. JoeBar07
    Eclair Apr 15, 2019
    JoeBar07 , Apr 15, 2019 :
    My guess is OP unlocked by developer options. I would go for what athaarv suggest or just leave it as is. Also there is nothing you can flash that makes that message go away.
    athaarv and Joffy_Jose like this.
  11. athaarv
    According to my knowledge, your bootloader doesn't unlock simply by checking "OEM unlocking". That only allows it to be unlocked. It's more of a precaution put in place to prevent accidental unlocks unless you definitely know what you're doing. To actually unlock it you need to run an ADB command after enabling OEM unlocking
    Edit: Fixed formatting error
  12. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Apr 15, 2019
    KeepTransisting , Apr 15, 2019 :
    You are correct. Checking the box simply allows for the unlock. The command has to be run for it to actually unlock.
  13. JoeBar07
    Eclair Apr 15, 2019
  14. Suyashkatta
    Eclair Apr 16, 2019
  15. akst
    Gingerbread Apr 17, 2019
    Praty_28 likes this.
  16. Praty_28
    KitKat Apr 17, 2019
    akst likes this.
  17. Sujknair
    Ice Cream Sandwich Apr 17, 2019
    Sujknair , Apr 17, 2019 :
    To be honest, ive gotten this dm-verity screen on a totally stock OOS, bootloader locked. Bootloader unlocking shows a different screen with yellow text, right?
    And running a command to reenable dm verity works for a while, then the whole scenario occurs again. Any ideas?
  18. akst
    akst , Apr 17, 2019 :
    I used to get this warning whenever I was reverting back to Oxygen OS. Using the adb command worked for me.
  19. akst
  20. Q1555480795854
    Cupcake Apr 17, 2019
