Message setup problem via OnePlus 7T
  1. RahulKumar5
    Froyo Sep 22, 2021
    RahulKumar5 , via OnePlus 7T , Sep 22, 2021 :
    In Message version 6.0.0.6 i am trying to setup "NEW AI POWERED ONEPLUS MESSAGE" feature but it can't setup every time i put up my both phone no. The otp will come but also a message display that, " phone varification failed! Incorrect OTP OR incorrect phone no. - pattern mishmash"
    Why this things happening again and again?
  2. ghostofcain
    Marshmallow Sep 22, 2021
    ghostofcain , Sep 22, 2021 :
    You've got two sims are you using the phone number of your default data sim?
  3. RahulKumar5
    Froyo Sep 22, 2021
    Yes bro... default data no. And putting no. In the appropriate field is same
  4. ghostofcain
    Try activating it with only the one sim onboard, I'm a little out of my depth as I only use a single sim.
  5. RahulKumar5
    Froyo Sep 22, 2021
    Ok...i will try
  6. RahulKumar5
    Froyo Sep 23, 2021
    RahulKumar5 , via OnePlus 7T , Sep 23, 2021 :
    Trying this also...but nothing can happen...same issue
