message
  1. Q1541967299295 Cupcake Apr 5, 2019
  2. Jammin619 Froyo Apr 12, 2019
    Q1541967299295 likes this.
  3. Q1541967299295 Cupcake Apr 12, 2019
  4. spdsk8race1 Honeycomb Apr 18, 2019
  5. Ytkuser Gingerbread Apr 25, 2019
    Ytkuser, Apr 25, 2019 :
    I have same issue but what update my stuff has not had a update for a long time.?
  6. Q1541967299295 Cupcake Apr 25, 2019
  7. Jammin619 Froyo Apr 25, 2019
    Jammin619, Apr 25, 2019 :
    have you tried using a third party messaging application to check to see if it is the native application or the hardware?
  8. Q1541967299295 Cupcake Apr 25, 2019
    Q1541967299295, Apr 25, 2019 :
    I have, no every one has the same 3rd party text message and what's the purpose of the service. I think TMobile need to send me another phone or take ownership of the issue
  9. spdsk8race1 Honeycomb Apr 25, 2019
    spdsk8race1, Apr 25, 2019 :
    try to edit the contacts number you're trying to text. delete the entire number then type it back in and save the edit and try texting again.
  10. Q1541967299295 Cupcake Apr 26, 2019
    Q1541967299295, Apr 26, 2019 :
    why do I need to do all that? TMobile or 1+6 need to get get IT department on that issue to resolve it. I have already to it for more than 10 contacts, I'm tired of keep on doing it.
  11. Jammin619 Froyo Apr 28, 2019
    Jammin619, Apr 28, 2019 :
    at this point if you get another phone it will not fix your issue as it is a software issue and not a hardware. replacing your phone is just going to do nothing. The software is approved by both the manufacturer and TMobile so unfortunately both are you blamem. there is rumor of one coming soon.
  12. Nick 59 Lollipop Apr 28, 2019
    Nick 59, Apr 28, 2019 :
    This is a USER forum. If you want help with your issues please just give us some details to work with. Ranting will help no-one. Details might include:
    Which version of OOS are you on?
    Which version of affected app(s)? (And what is it called? WHICH messaging app?)
    Are you rooted?
    Exactly when did the issue start?
    Exactly what happens and when?
    Have you searched for others with similar issue?
    What steps have you tried to resolve it?
    And anything else you can think of. If you cant do that then you could just raise a bug report here:
    https://forums.oneplus.net/feedback/
    spdsk8race1 and Q1541967299295 like this.
  13. Q1541967299295 Cupcake Apr 28, 2019
    Q1541967299295, Apr 28, 2019 :
    Nick59 I am not upset with you. One of the TMobile rep was trying to help me at the forum. I wanted her and T-Mobile to see that the issue wasn't solved.
    Nick 59 likes this.
  14. meatandy Nougat Apr 28, 2019
    meatandy, Apr 28, 2019 :
    I suggest you take the phone to a T-Mobile store and have it fixed in person.
    ironass likes this.
  15. Q1553245189323 Cupcake May 1, 2019
    Q1553245189323, May 1, 2019 :
    Hello! I'm facing issue In sending messages. it always showing error with message not sent . I tried everything even Factory reset my phone. changed 3 network.
  16. spdsk8race1 Honeycomb May 5, 2019
    spdsk8race1, May 5, 2019 :
    did this resolve the issue?
  17. spdsk8race1 Honeycomb May 5, 2019
    try to edit the contacts number you're trying to text. delete the entire number then type it back in and save the edit and try texting again. let us know if this resolved the ossie
  18. Q1541967299295 Cupcake May 5, 2019
    Q1541967299295, May 5, 2019 :
    I don't think changed of network is the problem, I believed 1+6 is having issues with its text message system and they need to solve it.
  19. spdsk8race1 Honeycomb May 5, 2019
    just a quick question, I was wondering if your issue did resolve itself once you did the edit to the contacts?
  20. Q1541967299295 Cupcake May 5, 2019
    No it's still doing for some contacts
