messaging taking 45% of the battery? what?
  1. Trexpass
    Froyo Sep 28, 2014
    Trexpass , Sep 28, 2014 :
    the picture should explain it all.
    how do I fix this? is it a known bug?
    also, I took it off the charger this morning, the screenshot was from this afternoon 4:00 pm I woke up at 10:00 AM so that's not 22 hours....
    thanks guys!
  2. LeonBayer
    Gingerbread Sep 28, 2014
    LeonBayer , Sep 28, 2014 :
    XD
  3. Chrisfaell
    Ice Cream Sandwich Sep 28, 2014
    Chrisfaell , Sep 28, 2014 :
    Try killing the process and shut down your phone and then start it.
  4. bhavsarrohit
  5. chillz88
  6. Trexpass
    Froyo Sep 28, 2014
  7. TakeMyMoney
    KitKat Sep 28, 2014
    TakeMyMoney , Sep 28, 2014 :
    lOl
    You must be out of your mind.
  8. flamingodise
    flamingodise , Sep 28, 2014 :
    It's 300€ by the wayyyyy..
  9. wbpbrian400
    Jelly Bean Sep 28, 2014
  10. EvilSpeaks
    EvilSpeaks , Sep 28, 2014 :
    Hopefully the next update expected next week will improve the battery again..... It was great on the 25R software and went downhill after 30O
  11. JuanL
    KitKat Sep 28, 2014
    JuanL , Sep 28, 2014 :
    Something is wrong with your one... Contact support. This is not a knoe issue... Its saying 22hrs while only 6 passed.
  12. sparkling_cyanide007
    Gingerbread Sep 29, 2014
    sparkling_cyanide007 , Sep 29, 2014 :
    That's very odd. Generally, what consumes the most battery should be Screen/Display. You could have a rogue app that triggers Messaging?? Have you tried to go into Settings and Force Close messaging? If not, I would reboot
  13. shashank.ag
  14. Cojy
    Cojy , Sep 29, 2014 :
    Could be that you have an issue receiving some text/MMS. I personnaly had the same pb, some MMS content could not be downloaded (cm software bug saying no apn configured) and so the app was trying to download over and over, it was stuck in a loop and it lead to this kind of consumption.
    I would suggest you have a look at your sms/mms and see if you have some message which is being downloaded, or something like that and delete it/cancel the dl.
    I don't see it as a bad battery, even if the battery was wrong you would still get balanced results accross applications/system percentages, only it would drop faster.
  15. Trexpass
    Froyo Oct 1, 2014
    Trexpass , Oct 1, 2014 :
    guys, calm down!
    it was something to do with the messaging app, I now use hangouts (basically the same) and the battery time is fine now! works fine nothing wrong, I'm fine! lol
    maybe a rogue app indeed but I don't feel like making a big deal out of this.
