OxygenOS Messed around with substratum and now in a bootloop... help!
  1. aviorx1
    Cupcake May 25, 2017
    aviorx1 , May 25, 2017 :
    Hey, i have a question, i don't how much it relates but im try.
    I have a custom rom based on oxygen os 4.0 (freedom os) on my oneplus 3 and it came with substratum thene engine, so i decided to try some beauty theme.
    On my first try to install theme i got stuck on bootloop, then, i installed a dirty flash and that solved it..
    So, i wanna ask you guys, which theme will work without bootloops on my phone (on this specific rom)
    Thank you guys :)
  2. aviorx1
    Thank you guys :)
  3. BobbyV8_
    The Showcase Reviewer May 25, 2017
    BobbyV8_ , May 25, 2017 :
    Modern UI is the best bet for Freedom OS (it doesn't have full OMS support) so betterstay out of substratum. If you ever apply it, do not apply to Android System. Applying it to android system makes the device reboot when you hold the power button for few seconds
    Praty_28 likes this.
  4. Vishal Vazandar
    Vishal Vazandar , May 25, 2017 :
    Everytime I try to power off my phone it goes into an endless loop and the only way to achieve power off is by doing a long press of the power button. Any solutions for this?
  5. aviorx1
    Ok, thanks for the answer, there is no some theme that i can use safely? Except moderm Ui
  6. BobbyV8_
    I've tried a dozen Themes and Modern UI worked best. You can use other themes too. The key for safe theming is to skip android system. Sometimes apps keep crashing in that case you need to leve those apps from theming
  7. BobbyV8_
    Which ROM are you using?
    Solution is to flash the rescue.zip / rescuelegacy.zip
    Instead clean flash ROM and skip theming android system.
    Before widely applying layers, check if the ROM supports OMS
  8. aviorx1
    Thank friend
  9. Vishal Vazandar
    Cupcake May 31, 2017
    Vishal Vazandar , May 31, 2017 :
    The problem seems to have solved itself. Will try your solution if it happens again. Thanks!
  10. Vishal Vazandar
  11. BobbyV8_
    The Showcase Reviewer May 31, 2017
  12. Balajii_Ch
    Eclair Jul 10, 2017
  13. PAPZI1957
    Gingerbread Aug 4, 2017
    PAPZI1957 , Aug 4, 2017 :
    I have bootloop after installed Ozone 4.2 [​IMG]
    Flashed Rescue_legacy, doesn't solved..
    Flashed again the full OB21 zip, doesn't solved...
    Haven't system/vendor/overlay folder...
    PLS help!
    Update: Only clean flash solved this mistake...
