Messenger Crashing Constantly CM12s
  1. LewisThomas
    Gingerbread Apr 17, 2015
    LewisThomas , Apr 17, 2015 :
    So I manually installed the update but Messenger keeps crashing and the notification keeps on popping up and I can't stop it!
    HELP!
  2. DaxNagtegaal
    Marshmallow Apr 17, 2015
  3. SomeSayImHandSome
    Apr 17, 2015
    SomeSayImHandSome , Apr 17, 2015 :
    i had issues with invalid numbers on 12S factory reset fixed it. i'll stick to Oxygen. it just works. we'll see what 12.1 brings to the table.
  4. LopezLuca
    Cupcake Apr 17, 2015
  5. LewisThomas
    I just used the update function with the CM bootloader, non rooted. That's it.
  6. DaxNagtegaal
    DaxNagtegaal , Apr 17, 2015 :
    OTA updating tends to cause these things, try a factory reset
  7. jordn808
    Froyo Apr 17, 2015
    jordn808 , Apr 17, 2015 :
    My issue is sending and receiving mms messages. Anyone experience that issue??? How can I resolve this? MMS works fine using Google hangouts. So I know is not my APN settings. Please help.
  8. TeamValor91
    Community Veteran Apr 17, 2015
  9. happyhippy
    Ice Cream Sandwich Apr 17, 2015
    happyhippy , Apr 17, 2015 :
    Problems happen with large ota updates. Do factory reset. Or better yet do a clean install using adb
  10. ageorgiou
    ageorgiou , Apr 17, 2015 :
    I have the same issue since updating to 12s I get the error unfortunately the process android.process.acore has stopped. I cant use my phone.
  11. mccannr1
    mccannr1 , Apr 17, 2015 :
    Yeah, I had these problems when I tried manually updating the OTA. Did a hard reset and everything then worked.
  12. ageorgiou
    where can i get step by step instructions?
  13. Lickeh
    Donut Apr 17, 2015
    Lickeh , Apr 17, 2015 :
    Exactly the same issue I had. Clearing cache partition, clearing the app cache, etc, all didn't work. In the end I had to do a factory reset from recovery menu and its completely fine now. Not the end of the world but a bit of a shame it had to be done.
  14. mccannr1
  15. phillyfreezer
    Honeycomb Apr 17, 2015
  16. ageorgiou
    Exactly what updates did you uninstall ?
  17. amjath
  18. takeabyte
    takeabyte , Apr 17, 2015 :
    For those saying to do a factory reset:
    I installed CM12 using the TWRPable zip, and managed to keep all my data, TWRP, and root (after flashing supersu again). Everything is working fine, except for the Display and Lights in Settings. Every time I choose it, I get a force close. Other apps force close, but not consistently, so I can live with that.
    When you say do a factory reset, do you mean in TWRP, or in Cyanogen's recovery?
  19. ceccorubik
    ceccorubik , Apr 17, 2015 :
    i do this after flashed on my opo with cm recovery, before reboot phone do a wipe cache. i suggest you go into recovery and do a wipe cache
  20. phillyfreezer
    phillyfreezer , Apr 17, 2015 :
    Just went to Google play and uninstalled the hangouts (not disabled) and my hangouts work again
