Working
Mi remote not working
  1. zzzharpreet Donut Jun 16, 2018
    zzzharpreet, Jun 16, 2018 :
    I loved Mi remote in my last mobile but when i open Mi remote in my one plus 6, it does not show my tv in search list. I don't know if this is an issue with application or one plus 6. Just wanted to check if i have to enable any setting ?
    Thanks
    ccclnaveen likes this.
  2. SomeBob Gingerbread Jun 17, 2018
  3. SomeBob Gingerbread Jun 17, 2018
    femiuex likes this.
  4. zzzharpreet Donut Jun 17, 2018
    zzzharpreet, Jun 17, 2018 :
    Hey. i am trying to search with wifi connection. It does work without IR blaster. You should be in the same network as tv. It was working fine on my moto g4 plus but does not work in one plus 6.
  5. SomeBob Gingerbread Jun 17, 2018
  6. SharmaPrakhar Cupcake Jul 2, 2018
  7. Sun90 Starting Point Expert Jul 2, 2018
    Sun90, Jul 2, 2018 :
    Oneplus devices doesn't have an irblaster
  8. SharmaPrakhar Cupcake Jul 2, 2018
  9. Sun90 Starting Point Expert Jul 2, 2018
    How will it ?
  10. SharmaPrakhar Cupcake Jul 2, 2018
  11. zzzharpreet Donut Jul 2, 2018
    zzzharpreet, Jul 2, 2018 :
    Mi remote supports 2 ways to control remote. Either with irblaster or with wifi. Wifi method should work on all the devices only when your mobile and your other device is connected to same network.
  12. Sun90 Starting Point Expert Jul 2, 2018
    Is it an Android TV you are trying to connect to.
  13. SharmaPrakhar Cupcake Jul 2, 2018
  14. zzzharpreet Donut Jul 2, 2018
    No. It's Mi tv with Patchwall OS.
  15. SharmaPrakhar Cupcake Jul 2, 2018
  16. Sun90 Starting Point Expert Jul 2, 2018
    Did you try the AP ( Access Point) isolation in the router as stated in that link you provided.
  17. zzzharpreet Donut Jul 2, 2018
    no it's not android. You can make it android with Mi tv box.
  18. Sun90 Starting Point Expert Jul 2, 2018
    Tried an IR blaster jack.
  19. zzzharpreet Donut Jul 2, 2018
    is it really required ? Same router and connection works for other mobiles(moto g4 plus and mi a1).
  20. SharmaPrakhar Cupcake Jul 2, 2018
    SharmaPrakhar, Jul 2, 2018 :
    no
