16
Mic is not working in one plus wireless z
  1. Caomhin
    Marshmallow Aug 27, 2020
    Caomhin , via OnePlus 6T , Aug 27, 2020 :
    Contact the OnePlus Support online chat in the link above your post.
    #61
    zayn_ys likes this.
  2. X1519718440970
    Donut Sep 1, 2020
    X1519718440970 , Sep 1, 2020 :
    I faced the same issue with mine today. Tried resetting the earphones and now it works. Can't guarantee it would work for you but it is definitely worth a shot if you haven't already tried yet.
    To reset your OnePlus Wireless Z earphones,
    Press the "Volume Up" and "Volume Down" button together for 10-12 seconds. You should hear 2 beeps which means they are reset.
    Like you did earlier, you can pair and connect to your device again and check if this resolves the issue
    #62
    Amitbhatt0 likes this.
  3. O1599481335139
    Cupcake Sep 7, 2020
    O1599481335139 , Sep 7, 2020 :
    Bro atlast i think I have a solution. It worked for me. Download BTMONO app from playstore. It has just on and off function. On it and it worked. Even after uninstalling the app it worked.
    #63
  4. Karan.Trehan
    Donut Sep 15, 2020
    Karan.Trehan , via OnePlus 6T , Sep 15, 2020 :
    The mic on the headset only works for phone calls not for whatsapp calls...and for everything else it uses the mic on the phone
    #64
  5. D1600340840980
    Cupcake Sep 17, 2020
    #65
  6. Caomhin
    Marshmallow Sep 17, 2020
    Caomhin , via OnePlus 6T , Sep 17, 2020 :
    Yes, they are posted within the previous 63 posts on this thread.
    #66
  7. G1603383039371
    Cupcake Oct 22, 2020 at 5:16 PM
    #67
