9
Mic issue. One plus one microphone not working properly
  1. Yaskamal
    Eclair Oct 17, 2014
    Yaskamal , Oct 17, 2014 :
    Hi,
    I got my one plus one phone two days back.
    I realised when ever i speak the other person cant hear my voice properly.
    he always complained that my voice just garbled a lot.
    I didn't believe him so I tried by myself and can also hear the same distorted garbled voice.
    Could anyone please help me if its software issue or Audio chip hardware issue.
    I'm really worried.
    kip23, origosh, JHong and 6 others like this.
  2. Raikon_N
    Gingerbread Oct 17, 2014
    Raikon_N , Oct 17, 2014 :
    My issue with mic is it's pickup, during video or audio recording, the resulting audio is always way too soft.
  3. mahek
    Donut Oct 30, 2014
    mahek , Oct 30, 2014 :
    mic not working during call but when i put it on loudspeaker it works
    augusto.fj, adawoud, acetrip and 5 others like this.
  4. milkdude
    KitKat Oct 30, 2014
    ramsabi likes this.
  5. Espeno
    Eclair Nov 12, 2014
    JHong, webdevgirl and ramsabi like this.
  6. TiagoLW
    Eclair Nov 13, 2014
    TiagoLW , Nov 13, 2014 :
    Same problem here..
    i read that we can solve it like this:
    1. Go to system/etc/mixer_paths.xml
    2. Mount system as R/W
    3. Open up mixer_paths.xml with Text Editor
    4. Scroll close to the bottom of the text, your little scroll position indicator should be about an inch up from the bottom of your screen(no on screen buttons)
    5. You will see <!-- Analog input devices --> and a bunch of text underneath.
    6. I wasn't entirely sure which mic would make this work so I changed the <path name+"main-mic"> value from 84 to 100. (Play around with the value until you find a sweet spot.) IF YOU GET ENVIRONMENTAL MICROPHONE INTERFERENCE, TRY TURNING THE VALUES BACK DOWN A BIT.
    7. Save the changed mixer_paths.xml and reboot your device for good measure
    im not sure how to do this.. can anyone help?
    ee456, RayoAnklesaria, Chugz and 2 others like this.
  7. TiagoLW
    Eclair Nov 13, 2014
    Please let me know if you solve this..
    avinash ravi likes this.
  8. Raikon_N
    Gingerbread Nov 13, 2014
    Raikon_N , Nov 13, 2014 :
    I'm not sure if it's the latest 44s or the app Viper4Android that fixes my low mic issue. Had a long hours of hangouts call with my family the other day and they said the audio is very good compared to the last time we did hangouts.
    TiagoLW likes this.
  9. TiagoLW
    Eclair Nov 14, 2014
    TiagoLW , Nov 14, 2014 :
    But it should be ok with the "normal" calls... what a shame..
    User5103 likes this.
  10. fletchisgreat
    Cupcake Nov 14, 2014
    fletchisgreat , Nov 14, 2014 :
    Should I buy the one on monday. I would like to use my smartphone to record lectures in college or will this be a problem?thanks
  11. TiagoLW
    Eclair Nov 17, 2014
    TiagoLW , Nov 17, 2014 :
    My OnePlus records well with the recording app.. the thing is with the phone calls. I hope they fix this with some update or something. I love this phone..
  12. shawn0223
    Gingerbread Nov 17, 2014
    shawn0223 , Nov 17, 2014 :
    you need to have a your OPO rooted and you need a browser that gives you root access. I use "root browser" from the playstore. DOwnload that, open and navigate to the file in step 1.
    ee456, ramsabi and TiagoLW like this.
  13. mithuntm
    Cupcake Dec 16, 2014
    mithuntm , Dec 16, 2014 :
    Is this issue solved ? I bought opo a few days back and people are complaining low sound whenever I am in a call
    TiagoLW likes this.
  14. TiagoLW
    Eclair Dec 16, 2014
    TiagoLW , Dec 16, 2014 :
    Hello.
    My phone started to work fine all of a sudden. I dont know what happened.. i swear I didn´t do anything.
    McAzzaMan likes this.
  15. Rann
    Froyo Dec 19, 2014
    Rann , Dec 19, 2014 :
    I am currently having this issue and I noticed some odd behavior. When I hold the phone to my ear and speak while in a call the other end can barely hear it if I speak loudly. Now if I hold the phone out horizontally as if I'm talking with speaker phone on the other end can hear it if I talk normal...kind of. I was continually talking and the other end would hear the sound go up and down in volume while I was talking. It was as if the phone was trying to auto adjust to higher sounds or something and reducing the volume.
  16. Pozzoi
    Donut Dec 21, 2014
    Pozzoi , Dec 21, 2014 :
    You need root and this workaround disables the noise reduction using the other microphones, it'll use only the bottom microphone for audio calls.
    The instructions:
    If you could, edit /system/build.prop. Change
    ro.qc.sdk.audio.fluencetype=fluence
    to
    ro.qc.sdk.audio.fluencetype=none
    Then, edit /system/etc/audio_platform_info.xml
    <device name="SND_DEVICE_IN_HANDSET_MIC" acdb_id="40" />
    to
    <device name="SND_DEVICE_IN_HANDSET_MIC" acdb_id="4" />
    Reboot.
  17. Rann
    Froyo Dec 27, 2014
    Rann , Dec 27, 2014 :
    That appears to have fixed my problem!!! Thanks so much, that was frustrating the hell out of me.
    ramsabi likes this.
  18. lloydss
    Cupcake Dec 27, 2014
    lloydss , Dec 27, 2014 :
    I have the same problem but have no experience of rooting, is it doable for a novice?
  19. ramsabi
    Jelly Bean Dec 27, 2014
    ramsabi , Dec 27, 2014 :
    It is doable if you are very careful, research thoroughly, ask if you are even a little bit uncertain. Lot of guides in the forum about rooting. Start with user @gusuraman 's link to rooting basics in his signature on the right.
    And take a backup before anything.
    lloydss and gusuraman like this.
  20. beinisch
    beinisch , Dec 27, 2014 :
    no root needed , just close the back mic with something... its echo from the noise canceling system
    deepak_irukula likes this.
