3
Mic not working
  1. G_Sanjai_S_azeg
    Gingerbread Mar 1, 2019
    G_Sanjai_S_azeg , Mar 1, 2019 :
    Recently i had issues with mic which is not working while using headphones. Without headphones it is working properly.. Can anyone help me out to fix this problem.
  2. N1548601374432
    Cupcake Mar 2, 2019
    G_Sanjai_S_azeg likes this.
  3. G_Sanjai_S_azeg
    Gingerbread Mar 2, 2019
  4. UdayReddy03
    Donut Mar 2, 2019
  5. PrashantKarma
    Ice Cream Sandwich Mar 3, 2019
  6. P1507997257550
    Cupcake Mar 3, 2019
  7. Satya U
    Froyo Mar 4, 2019
    Satya U , Mar 4, 2019 :
    i have the same problem.. i had to remove and connect two or three times to make the headset mic working
  8. Mkmanis11
    Gingerbread Mar 4, 2019
    Mkmanis11 , Mar 4, 2019 :
    same here bro.. its random for me..sometimes it works and sometimes it doesnt.
  9. G_Sanjai_S_azeg
    Gingerbread Mar 5, 2019
  10. F_Parasuraman_Deimos_dlR
    Donut Mar 5, 2019
  11. G_Sanjai_S_azeg
    G_Sanjai_S_azeg , Mar 5, 2019 :
    Too many peoples have same problem.. I waited for 2 days but no one posted any comments. So I thought that it is a hardware problem and took to local repair shop. Even he cannot solve issue.. It might be software issue.. I was planning to take a 5g oneplus device but i won't. May be this is my last device of oneplus bz of software issues related to mic, rear camera focus issue etc.. Made me to go to repair shop.. Lets @OnePlus find a solution.
  12. G_Sanjai_S_azeg
    Gingerbread Mar 6, 2019
  13. PawOne56
    PawOne56 , Mar 6, 2019 :
    clean the place you plug the earphone using the ear plugs .Be careful with the cotton try to remove them.
  14. HARI_HP
    HARI_HP , Mar 6, 2019 :
    both my headset microphone & phone speaker on top is not working... I'm basically talking on speaker nowadays... #neversettle
  15. G_Sanjai_S_azeg
  16. G_Sanjai_S_azeg
    G_Sanjai_S_azeg , Mar 6, 2019 :
    Anyone please let me know, can we use type c headphones for calling in 3t after the recent stable update? Since I have mic problems in headphone jack
  17. ghostofcain
    Marshmallow Mar 7, 2019
    ghostofcain , Mar 7, 2019 :
    Yes you can, your device also supports Bluetooth, so if you are unable to rectify this hardware issue, you could also use a Bluetooth headset.
    Please don't cross post issues, it actually makes it less likely you'll get an answer as many users will just totally ignore your posts.
  18. G_Sanjai_S_azeg
    Gingerbread Mar 7, 2019
    G_Sanjai_S_azeg , Mar 7, 2019 :
    Thanks bro.. Let me buy one
  19. G_Sanjai_S_azeg
    Gingerbread Mar 8, 2019
    G_Sanjai_S_azeg , Mar 8, 2019 :
    For normal calls it was working fine but when switch to video call or pubg games, voice comes through speakers.. Anything wrong with my settings? I turned on otg storage and audio source
  20. Ramesh Madrekar
    Donut Mar 8, 2019
