Mic on ANY headphones does not work via OnePlus 5T
  1. djel4468
    Cupcake Mar 4, 2020
    djel4468 , via OnePlus 5T , Mar 4, 2020 :
    It doesn't matter what wired headset I plug into my OnePlus 5T, the mic does not work, including original bullet v2. Every one of them (and I've tried six so far) that does not work in my phone works on my wife's (Note 8). I'm not sure when this broke but I need to know...hardware or software issue? My last ditch attempt was the bullet v2s [e]1f614[/e].
    Lavender326326 likes this.
  2. Waveform Modifier
    Marshmallow Mar 4, 2020
    Waveform Modifier , Mar 4, 2020 :
    Clean your headphone port.
  3. djel4468
    Cupcake Mar 4, 2020
    Thx. Tried that; not even static sound. Nothing since update. can listen to music but no one can hear me and I can't hear myself on a call.
  4. Vandit_S.S
    Gingerbread Mar 4, 2020
    Vandit_S.S , via OnePlus 5T , Mar 4, 2020 :
    Have you given the required permissions to phone/call/songs or whatever is required to work earphones and it's mic proper ?
  5. djel4468
    Cupcake Mar 4, 2020
  6. djel4468
    Cupcake Mar 4, 2020
    The buttons on the v2 bullets for volume up/down do not even work...and that's the same for every headphone I've tried. Yet these headphones work perfectly for music or phone calls on any other phone we have. I've scoured the forums and I don't even see an official answer for the issue.
  7. samikojo
    Froyo Mar 4, 2020
    samikojo , Mar 4, 2020 :
    Your headphone jack might be broken then. I use two different wired headphones with my OP5 and they both work just fine, mic included.
  8. Vandit_S.S
    I hope that you're not using beta version of OnePlus.
    If yes then go to stable version and try
    If no then I hope that your phone is currently on 9 0.10 version
    Downgrade it to lower version ( I don't know how to downgrade it but you can search it on Community or Google it)
    Hope that downgrading will work
    And can you let me know that from when you're facing this issue? Is it before the 9.0.10 or from past few days.
  9. djel4468
    Cupcake Mar 4, 2020
  10. djel4468
    Cupcake Mar 4, 2020
    I've had my OP5T since it was released.
    I'd be happy to downgrade...two questions...
    1) downgrade to which version?
    2) how do I back up the whole phone? My storage is 80% full.
  11. Vandit_S.S
  12. J1511283103137
    Cupcake May 19, 2020
    J1511283103137 , May 19, 2020 :
    Exactly same issue over here. I tried 4 different branded wired headsets (all in audio jack). I tried phone calls and skype calls. The headsets do work in other phones.
  13. Vinay Nadig
    Cupcake Mar 8, 2021
    Vinay Nadig , Mar 8, 2021 :
    I'm facing the exact same issue in my OnePlus 7 since a month. I think there was a system update a month ago. Earphones work perfectly fine for all other media but microphone of earphone stops working during calls (voice, whatsapp, zoom, etc)
    Unable to find a solution since on any platform.
  14. Vinay Nadig
    Cupcake Mar 8, 2021
    How did you resolve this issue? I am facing the same problem.
  15. Vinay Nadig
    Cupcake Mar 8, 2021
    Were you able to resolve the issue? I'm facing similar problem now on my OnePlus 7 since my last system update.
  16. #16
