Sound Microphon, jack and speaker not working
  1. gryzli
    Cupcake Jul 1, 2019
    gryzli , Jul 1, 2019 :
    Hello, I've got a big problem with my OnePlus 3 microphone, jack and speaker. They only work for a few minutes after restarting the phone and then phone doesn't recognize that headset is plugged and microphone stops working. I have tried everything: factory resetting, disabling google assistant, replacing microphone with usb port and mini-jack, upgrading to android Pie beta, cleaning ports, bought new earphones, installed custom rom and nothing helped. Recently also the main speaker stopped working. Is there anything I can do?
    Menyar likes this.
  2. Paschfire
    KitKat Jul 4, 2019
    Paschfire , Jul 4, 2019 :
    If after performing a factory reset and the issue still persist, it highly likely some sort of HW damage/failure has occurred.
    I suggest you take or send your device into a OnePlus service center for inspection of possible repairs.
    Vishal Priajapati likes this.
  3. Vishal Priajapati
    Cupcake Jul 15, 2019
    Vishal Priajapati , Jul 15, 2019 :
    I am facing same issues still I am not received any proper solution and justification from service station
    while you visit bat service station simply they say need to replace mother board
