Microphone issue with OxygenOS
  1. B@nn3R
    Froyo Apr 8, 2015
    B@nn3R , Apr 8, 2015 :
    I had the problem either on CM11S and on Lollipop OxygenOS.
    On CM11S I solved by following this procedure
    https://forums.oneplus.net/threads/fixed-for-good-microphone-issue.222059/
    Now I'll wait anxiously hoping that the OPO as a replacement does not recur the same problem (or more!)
    @kyle_evans17 thank you so much for the fix anyway!
    #41
  2. kyle_evans17
    Froyo Apr 8, 2015
    kyle_evans17 , Apr 8, 2015 :
    No problem! Tbh i think every manufacturer has had problems implementing lollipop so far its trial and error
    #42
  3. B@nn3R
    Froyo Apr 8, 2015
    It 's true! Even Google has had problems with Lollipop early :)
    But I do not think this problem is related to the OS. I think it's a hardware malfunction of the noise reduction system during calls, which can be mitigated by software by editing some files.
    #43
  4. knapp870
    Cupcake Apr 8, 2015
    knapp870 , Apr 8, 2015 :
    Any ideas how I can get an RMA or log a ticket without an order #? I'm trying the fix listed above but have my doubts.
    #44
  5. knapp870
    Cupcake Apr 8, 2015
    #45
  6. nadeempatel
    Froyo Apr 8, 2015
    nadeempatel , Apr 8, 2015 :
    Just fine after flashing..
    #46
    B@nn3R likes this.
  7. diwakargoel
    Cupcake Apr 8, 2015
    #47
  8. knapp870
    Cupcake Apr 9, 2015
    knapp870 , Apr 9, 2015 :
    Same Here. I also contacted Oneplus and they refuse to help me because I don't have an order#!!
    #48
  9. B@nn3R
    Froyo Apr 14, 2015
    B@nn3R , Apr 14, 2015 :
    I've updated my OPO to CM12S and the microphone issue was fixed!
    I've asked to OP to close my RMA because "better the devil you know than the devil you don’t" :p
    #49
  10. Hanz1127
    Ice Cream Sandwich Apr 26, 2015
    Hanz1127 , Apr 26, 2015 :
    I have the same problem , i have updated manualy to cm12s (yng1tas0yl) and the problem is not fixed. Maybe with the OTA cm12s version ?
    Thx
    #50
  11. B@nn3R
    Froyo Apr 26, 2015
    B@nn3R , Apr 26, 2015 :
    something strange it is happened after upgrading to me: after the OTA to CM12S microphone works fine, but had disappeared the Whatsapp and Telegram apps by my OPO . So I reinstalled them from the Play store and immediately after installing the microphone stopped working!
    I tried to remove them to see if the microphone was beginning to work again, but nothing has changed.
    I had to follow the guide at this link to solve the problem:
    http://forum.xda-developers.com/oneplus-one/development/fix-low-mic-call-t3055661
    changing the following line in the build.prop file:
    BEFORE FIX
    ro.qc.sdk.audio.fluencetype=fluence
    persist.audio.fluence.voicecall=true
    AFTER FIX
    persist.audio.fluence.voicerec=false
    persist.audio.fluence.speaker=false
    #51
  12. tdesmet
    Cupcake Apr 26, 2015
  13. B@nn3R
    Froyo Apr 26, 2015
    #53
  14. Hanz1127
    Ice Cream Sandwich Apr 28, 2015
    Hanz1127 , Apr 28, 2015 :
    Its OK for me, i flash the files on opo and the communication in call is perfect . im on cyano not oxygen
    Thx @B@nn3R
    #54
    B@nn3R likes this.
  15. pedromfaria
    Cupcake Sep 29, 2015
    #55
  16. TherecanbeonlyONE33
    Cupcake Dec 8, 2015
    TherecanbeonlyONE33 , Dec 8, 2015 :
    SAME ISSUE! :( missing file paths
    #56
  17. TherecanbeonlyONE33
    Cupcake Dec 8, 2015
    #57
  18. Kumarn86
    Cupcake Dec 15, 2015
    #58
