6
Minimum display brightness
  1. BrightHulk
    Cupcake Feb 2, 2018
  2. svekl
    Eclair Feb 2, 2018
    svekl , Feb 2, 2018 :
    How do I submit it?
  3. svekl
    Eclair Feb 2, 2018
    Yes, sure, I set it to lowest without automatic brightness, but I would like to have an even darker option. I'm sure screen itself can do it, because battery saver does it and all these apps with dark overlay can do it, but overlay can't darken navigation buttons.
    I had Nexus S long time ago, maybe with some custom rom, and it had really good lowest value.
  4. G_ag_5t
    Gingerbread Feb 2, 2018
    G_ag_5t , Feb 2, 2018 :
    Use the night screen app.It will reduce brightness even after the default minimum brightness.I too find the minimum brightness to be bright enough to strain eyes.But it happens only at night or dark situations.This app will reduce the brightness even further, the minimum brightness.
  5. svekl
    Eclair Feb 2, 2018
    App doesn't reduce bottom buttons brightness. And it's a hack any way. As a software developer I feel it's not acceptable that a lot of people have to use hacks instead of simple fix in firmware, especially when we talk about Oxygen OS, that is perfect in all other things.
    artorrado likes this.
  6. svekl
    Eclair Feb 2, 2018
    I would not insist on this fix if it was only about me, but it's a very common problem in internet over all devices. You even don't need to look in Google to understand that, just look how popular are these screen dimmer apps in Market, it's a real issue for a lot people.
  7. svekl
    Eclair Feb 2, 2018
    Just a random app for example. Over million downloads! And there is a bunch of apps like that in Market. So it's a real issue for sure.
    artorrado and zetapulse like this.
  8. artorrado
    Cupcake Nov 2, 2019
    artorrado , Nov 2, 2019 :
    And two years later, still in the same situation. Absolutely unacceptable.
  9. stark2991_PL
    KitKat Nov 3, 2019
    stark2991_PL , Nov 3, 2019 :
    What exactly is unacceptable? OnePlus 5T's screen can go down to just 2 nits of brightness. Software update can't change it because it's hardware limited. What do you expect?
  10. E1579074105334
    Cupcake Oct 26, 2020 at 12:23 PM
    E1579074105334 , Oct 26, 2020 at 12:23 PM :
    The brightness control on oneplus nord sucks. It is not optimized in nord. I have used oneplus 7T that does not have any such issues.
    I am using 'Lux Lite' on oneplus nord from the play store, does the job perfectly. It has levels much below the stock auto brightness option and smart enough to detect day or night. Try it
  11. BeardyBiceps
    Ice Cream Sandwich Oct 26, 2020 at 6:44 PM
