2
Network/Connectivity MINT SIM--Sim and network settings, Access Point Names (APNs) settings, VoLTE and Data Connectivity
  1. azfarniazi
    Donut Dec 9, 2017
    azfarniazi , Dec 9, 2017 :
    1. Tap “Settings
    2. Tap “SIM and network” under “Wireless and networks
    3. Tap “Mobile data” under “Cellular data” to turn it off
    4. Tap “SIM 1 (Mint)
    5. Tap “Access Point Names
    6. Tap “+
    7. Fill in the following required fields:
    Name: T-Mobile US LTE
    APN: fast.t-mobile.com
    Proxy: Not set
    Port: Not set
    Username & Password: Not set
    Server: Not set
    MMSC: http://mms.msg.eng.t-mobile.com.mms/wapenc
    MMS Proxy: Not set
    MMS Port: 80
    MCC: 310
    MNC: 260
    Authentication Type: Not set
    APN Type: default,supl,mms
    APN protocol: IPv4
    APN roaming protocol: IPv4
    APN enable/disable: APN enabled
    Bearer: Unspecified
    MVNO type: None
    MVNO value: Not set
    10. Tap “three dots in the top right corner” then tap “Save
    (Tapping save will take you back to APNs menu and in this menu first option would be selected that is
    T-Mobile US Data
    Fast.t-mobile.com
    11. Go back 2 screen by tapping “back arrow (ß)” twice
    12. Tap on “Mobile data” under “Cellular data” to turn it on
    13. Restart the phone
    14. Turn on "VoLTE" under "Enhanced communications" if you want VoLTE enabled
    Thank you ONEPLUS and MINT SIM
    Regards, Azfar
    jv004 and Varking like this.
  2. dskaufman
    Cupcake Aug 13, 2019
    dskaufman , Aug 13, 2019 :
    UGH. This does not work with my MINT SIM (used in position 2) and my OnePlus 6. Any other suggestions out there? The suggested settings given by MINT (i.e. Ultra) don't work either. I have yet to find a solution anywhere to being able to send or receive MMS with MINT Mobile.
  3. G_Abhisesh_Acharya_gaPi
    Cupcake Aug 17, 2019
    G_Abhisesh_Acharya_gaPi , Aug 17, 2019 :
    I am using Mint Mobile on my OnePlus 5. My data was slow initially but I solved it by going to the "data usage" section inside the settings of each app I wanted to use data for and enabling its data usage. The Mint Mobile customer service also suggested removing my sim card for 15 mins and then putting it back in, which helped increase the data speed. Hope this helps!
  4. jv004
    Cupcake Sep 3, 2019
    jv004 , Sep 3, 2019 :
    in case it wasn't clear, the manual input on APN settings are case sensitive and space (yes the white space), like if it needs a capital letter, use a capital letter, no space? don't add a space.
  5. jv004
    Cupcake Sep 3, 2019
    I do have a question though: is there any difference if use the "fast TMobile" APN settings vs the "Ultra" APN settings that mint provides? thanks!
