764
Mirrors for official Cyanogen roms & OTA updates
  1. pacha
    Froyo Apr 12, 2016
    pacha , Apr 12, 2016 :
    Same happened to me using the tracker incremental upgrade.
    I had to eventually do a reset.
    All OK now but I will do a reinstall when the full zip is available.
    If your back button is off screen, non capacitive, you can use it to back track in the restore menus.
  2. Green1230
    Honeycomb Apr 12, 2016
    Green1230 , Apr 12, 2016 :
    Dude, just wait. From my experience the OTA rollout percentage should be around 5 % by now. And a suspiciously large number of people that have issues with the update seem to have flashed it via recovery. So I'd say, if you're not absolutely sure what you're doing (and judging by your unawarwness of why you haven't gotten the OTA yet, you don't), just wait a couple of days or maybe a week for the rollout percentage to hit 100 % and you'll surely get the OTA by then.
    Qazi.Rza and murtuzahb like this.
  3. Spannaa
    KitKat Apr 12, 2016
    Spannaa , Apr 12, 2016 :
    I doubt it'll includes apps root, probably just adb root as before (but I may be wrong).
  4. matssa
    Ice Cream Sandwich Apr 12, 2016
    matssa , Apr 12, 2016 :
    Ok thanks, I thought it would be like CM13 (built-in root). Cause on the COS13 zip file, root access isn't full access, only partial (some apps can't manage to have root, even though the same app works fine on CM13).
    Can't wait for official zip :)
  5. sunnyshaan
  6. techx
    Gingerbread Apr 12, 2016
    techx , Apr 12, 2016 :
    Their reply will be scripted, this can turn two ways, 1. try flashing the rom again, 2. we'll push it in a future update. I'll search around, somewhere something about this will pop up... :D If others can weigh in on this, provide some info, that will do.. :)
  7. tedddy
    Ice Cream Sandwich Apr 13, 2016
    tedddy , Apr 13, 2016 :
    How can we view the OTA roll out percentage? The old link I has doesn't work.
  8. ElRobertson
    Gingerbread Apr 13, 2016
  9. virdi.gs
    Cupcake Apr 13, 2016
    Krizzii likes this.
  10. Spannaa
    KitKat Apr 13, 2016
    Spannaa , Apr 13, 2016 :
    It's a RickRoll.
    21,776 clicks and counting...
    Krizzii, ABundy, apfo and 3 others like this.
  11. mtlvmpr
    Donut Apr 13, 2016
    mtlvmpr , Apr 13, 2016 :
    You might break a record at this rate :O
    This is a thread for official roms. And that rom has been linked couple times already.
  12. virdi.gs
    virdi.gs , Apr 13, 2016 :
    I was not aware that u release ROMs (very sorry), I reached here searching for the solution for my BRICKED OPO after that incremental update from CM12.1 to 13 (Update Tracker app). Bricked my phone into Boot-Loop, did a complete factory reset, no use, connected to PC in fastboot mode, patched recovery, then updated via system update notifiers. After hell lot of head banging at least now I'm back with 5.1.1
    Top volume of phone is almost gone, sad but phone is working now. I used to download the file, flash from recovery boot option, but..... I'm Too scared to update again to CM13 from the notification (update tracker).
  13. manthan
    manthan , Apr 13, 2016 :
    Does anyone know how to update from CM13 Snapshot to latest OTA release ?
    I installed TWRP and flashed the Snapshot.
    How to get the latest release update?
  14. yashk1611
    Eclair Apr 13, 2016
    yashk1611 , Apr 13, 2016 :
    Download fastboot zip of YOG7DAS2K1 bulid from www.cyngn.com/support, flash it through fastboot and then download the incremental zip from the first post of this thread and flash it through the recovery (because you will be on stock Cyanogen recovery now). Don't try this while you're on TWRP.
  15. sayem
    Eclair Apr 13, 2016
    sayem , Apr 13, 2016 :
    I reverted back stock recovery from TWRP to be able to get the OTA, but when OTA downloads the update file and prompts "install update", then after tapping it the phone reboots and shows some progress and goes to CM Recovery and shows the menu. If i hit reboot it loads COS 12.
    What am i doing wrong???? Please help.
    Thanks.
  16. lebanese_boy07
  17. Green1230
    Honeycomb Apr 13, 2016
    Green1230 , Apr 13, 2016 :
    You can't. Cyanogen changed the protocol so the update app doesn't access this info anymore.
    It's just that I've been around several updates and have been checking the percentage regularly when I still could. So I've gotten a bit of a feeling about how they roll these things out.
  18. jrohrich
    Donut Apr 14, 2016
    jrohrich , Apr 14, 2016 :
    I'm on CM 13 and I need to get back to 12 since none of my apps work on 13. I'm not sure which one of these I need though. What is the data partition? Do I care if it gets overwritten? Not sure which I need to download or how I need to get it on the phone. Thanks in advance for any help
  19. Carlo_MH
    Froyo Apr 14, 2016
    Carlo_MH , Apr 14, 2016 :
    Question: If I'm using Cyanogen OS 12.1.1 in my OPO with root and TWRP.
    Do I have to use Signed flashable zips to update to 13 and don't lose my data
  20. meknoy
    Cupcake Apr 14, 2016
